61 - 80 of 129 Posts
Discussion starter · #61 ·
i have heard that the duelers in the 315 rear width are actually slightly wider than a normal 315. Did you have any issues with rubbing? You have SRT8 springs and bilsteins right?
I have a set of 20x9 reps on right now....I am going to set them up with some winter tires and use them only in the cold months. So I can go with a summer only tire on the OEM wheels :thumbsup:
yes, i have srt springs and srt bilsteins. i noticed a tab bit of rubbing on the plastic wheel well in the rear so i heated it up with a heat gun and rebent the wheel well to a more curved shape in the spot where it rubbed. took like 5 min and now it doesnt rub at all :thumbsup:
Hey, love what you've done bro. Question on the tires as well, you said they rubbed wheel well, was there any sway link clearance issue on either side? Which links are you running and do you have the slim bolt heads by any chance? Ive seen its hit or miss on some SRTs with 315s and was curious how they fit out on yours . . .
Discussion starter · #63 ·
i have the wk bwoody sway links on my jeep with the bolts that came with the links. there is not issue with the links rubbing the wheels. i only had the slight rubbing on the plastic liner that was a super simple fix.
