I am getting this same message on my 06 Jeep Grand Cherokee 5.7L. I got the message a while ago, took it to a transmission shop and they replaced the module/temperature sensor inside the transmission. And it came on the very next day. Went back to the shop and thrry let it sit and run for hours checking the temp and it never got hot. At first it only came on after a long drive then putting in in park and let it sit and run for a few minutes. It's now coming on almost every time we drive it. I also have the service tire pressure system warning that comes on every time I drive it too. This also came on just once in a while but now comes on every day now. Any suggestions or updates in this?
I have 05 Jeep GC with the 5.7 HEMI, 214k miles. I've had similar problems. The symptoms were sporadic. The AT gets stuck in 3rd while the FAN goes on max speed. Sometimes, I get the Trans Fluid overtemp msg. I get no codes from the scanner. When I disconnect the battery, OR remove the fuse for the PCM for few seconds, and reconnect, the AT runs just fine as long as I don't turn off the car. Sometimes I get a code for no communication with the TCM. That's a hint right there!
Here are the things I've until I've finally fixed the problem (pulled my hair on this one):
1. Changed trans fluid & filter, Replaced the pan with new one with plug. Forget about using the old pan. Just drill a hole in it to drain w/o the mess of spelling over. no good.
2. Replaced the valve body with rebuilt unit. no good.
3. Replaced broken ground straps to the PCM and under the car when AT is has one connected to chassis. no good.
4. Replaced Input/Output speed sensors attached to the AT. no good.
5. Attached a quick Battery disconnect switch. That was a good workaround as retting the PCM fixed the problem temporarily until next trip. Thought about adding a battery disconnect with remote.
6. I sent my PCM to a repair ship called "SIA Electronics" in eBay. They found no issue with the PCM. They charged me a diagnostics fee and sent it back as is. No good.
I'm pulling my hair cause I'm running out of ideas.
7. Took my Jeep to a Stealer dlr. They did the recalls and updated the software on my PCM for $175. no good.
8. Decided to buy a refurbished PCM from eBay seller called "importapart", and gave them the VIN & miles. I got the PCM in 2 days. Plugged it in in 5 mins, and wallah...!!!! It worked!. Took the truck on multiple drives and tried turning off and restarting. That worked!!
Bottom line, it was a faulty PCM all along. Even if you get no codes. A bad PCM has a mind of its own.
Beware tho. Those PCMs are expensive. I highly recommend buying it from a seller that does the programming for you for Plug & play. Do NOT buy a used PCM that requires you to take it to a dlr for programming.
