Looking To See If Anyone Knows Where I Can Get A Budget 4" Lift Kit For My 05 Grand Cherokee 4x4 Laredo 3.7 V6?
or dont do it at all. :thumbsup:Budget kits are around 2 inches. Rocky Road Outfitters, Rough Country etc... They will net you around 2 inches of lift in the $200 vicinity.
Your next step is the OME, which if you go with the OME HD will net you 3 inches for around $300 for the springs plus the cost of shocks.
Then there is the Superlift for $1500 which will net you 4 inches. Or you can spend crazy money on the JBA which will do nothing more then the SL but cost double.
Now I know what your thinking. why don't I just put a $200 lift on top of $300 lift. Well by all means go for it but understand that you will cost yourself a couple thousand in repairs if you do so.
As I have said a thousand times, do it right, do it once and buy the Superlift.
You are correct:lol: That is if all you want is bigger rubber and no plans to wheel it.or dont do it at all. :thumbsup:
god damnit lucas... dont put me out there like that :lol:You are correct:lol: That is if all you want is bigger rubber and no plans to wheel it.![]()
No offense but the RK is the biggest POS lift made for the WK. It nets less then 1.5 inches at best. It's the last lift I would ever consider installing.What about the rock krawler x factor 3.5" lift. Its fairly budget for under $500.
http://www.rockkrawler.com/SearchResults.asp?Cat=1825
