Welcome to the forum. The stock setup is a fairly restrictive chambered silencer and the SRT8 tube is less restrictive. Just switching over won't make a world of difference but it will help a little, especially at higher RPM. If you're after better airflow through the intake, along with the SRT8 tube, you should consider adding a second inlet to the airbox (see pix below), and a high flow air filter element. This will help a bit more, but again, more so at higher RPM. Putting around town, you'll not probably notice any difference with any of these mods. Your throttle response and fuel economy (probably only on the highway) may also improve slightly.
Remember, most mods don't make a huge difference by themsleves but, cumulatively, they do add up. The only mods. I've found that make a huge difference are a complete low restriction header back exhaust system (should be done first) and a well selected, mild performance cam and kit. Those two mods alone, along with your custom CAI and a good tune, are worth about 75-90 horsepower. My 06 Overland is fairly well modified and, at its best, increased horsepower by about 100-125 horsepower and increased the highway fuel economy by about 25%.
