1 - 9 of 9 Posts
GCSRT8
You '06 boys feeling left outta the rear fog club? No fear, I've made provisions for you.
This thread is for the harnesses that work with '06 Jeeps (3-bulb taillights). If you like what you see here but have an '07+, check here: http://jeepgarage.org/showthread.php?t=1286
*****PLUG-N-PLAY REAR FOG LIGHT ACTIVATION HARNESSES*****
These harnesses are for '06 SRT8's with the 3-bulb taillights. They plug into your 4-pin trailer wiring and plug in to the rear fog light on each side. They give you 3 functions: running lights, brake lights, and turn signals. THESE HARNESSES ARE 100% PLUG-N-PLAY. Here are some pics:
Plugs into your ACTIVATED 4-pin trailer wiring:
Other ends plug into your rear fog lights:
I include a cover to put over your existing wiring (if you have it):
They are currently offered in 2 flavors:
"STOCK" HARNESS:
This harness utilizes all stock components. Every SRT8 Jeep I've come across already has bulbs and bulb sockets in the rear fog lights. This harness will activate these rear fogs without anything more than a 5-minute installation. Now, I realize the bulbs in the rear fogs are single-filament bulbs. Don't worry. Due to some fancy wiring, I was able to make them function as dual-filament bulbs, giving you running lights, brake lights, and turn signals with the stock setup. This harness will only work with incandescent bulbs. IT WILL NOT WORK WITH LED BULBS!!! If you prefer to run LED bulbs, check out the "LED" harness below.
"LED" HARNESS
This harness is for the discrimating jeep owner who wants to run LED bulbs in everything. It works the same as the stock harness, but is constructed to work specifically with LED bulbs. The bulbs I designed them to work with are from V-LED's, here's the link: http://www.v-leds.com/Exterior-LED/P...35724-1-2.html Other members have confirmed that they do work with other LED bulbs, but I do not have any sort of list of what works and what doesn't. I do NOT provide any bulbs. The harness is still 100% plug-n-play, but with the added step of replacing your bulbs with the LED ones (a 2-minute job). You still get all 3 functions - running lights, brake lights, and turn signals. This harness WILL NOT WORK WITH INCANDESCENT BULBS!!! If you prefer incandescents (or want to use the stock bulbs), check out the "Stock" harness above.
*****IMPORTANT NOTES ABOUT HARNESSES*****
First of all, the number one point of confusion with these is that the taillights you have on your Jeep matter in harness selection. THEY DO NOT! The only thing that matters is what type of bulbs you want to run IN YOUR REAR FOG LIGHTS! If you wanna use stock bulbs, get a stock harness. If you wanna use LED bulbs, get an LED harness. If you have LED taillights, this does NOT matter at all.
Second, the harnesses are NOT interchangeable. If you buy a stock harness and try to use LED bulbs, there will be no noticeable difference between your running lights and brake lights/turn signals. Conversely, if you buy an LED harness and try to use incandescent bulbs, your running lights won't come on at all (accompanied by the good possibility of frying the harness).
INSTALLATION
Installation is simple, usually requiring less than 5 minutes. Plug one end into the trailer wiring, plug the other ends into your rear fog lights. I currently don't have a writeup on this. If there is big interest in these, I will do one. Otherwise, I will offer the first person to do a writeup a $50 "rebate" on their harness.
PRICE
Price for either harness is $125 + $5 shipping in the USA. I ship using USPS Priority Mail because it is both cheap and quick. I do ship international, however additional shipping costs are involved. So far, I've only shipped internationally to Canada, so I know that is $15 extra. If you'd like them shipped to another country, PM me and I'll quote you.
Furthermore, as an option, I can build the harness with a pass-thru on the 4-pin connector so you can tow without unplugging the rear fogs. This is $10 more ($135 total + shipping).
*****CONTACT INFO*****
If you're interested in getting a harness or have questions, you can PM me. Alternatively, if you don't have any questions and just want to buy one, you can send paypal payment to [email protected] . Be sure to include your forum username, the year of your jeep, as well as harness type (Stock or LED) and whether or not you want the pass-thru.
2005 Grand Cherokee
If i ever get my rear SRT bumper and it does not come with lights for some reason, do i need to use a single filament bulb or should i buy a double filament bulb should i choose to not do LEDs? (or for future bulb replacement reasons)
GCSRT8
Kyle:
If when you say "and it does not come with lights for some reason", I am assuming you mean bulbs. If that's the case, I would just get a single filament bulb. Any standard 1156 bulb will work. My harness is set up to use single filament bulbs so it's just easier that way. If you get a dual-filament bulb, you're gonna be modifying bulb sockets and other stuff like that.
What I have done for other people in the past if they change their mind about LED bulbs is "exchange" harnesses. Say you buy a stock harness and then a few months later, you decide to swap to LED taillights. At that point, you want your rear fogs to match. If you pay for the shipping ($5) and send your "stock" harness back, I'll "exchange" it for an LED one. So you see, you really can't go wrong. Get what you want at the time and if you change your mind, no problem.
2005 Grand Cherokee
Sorry, thats what i meant, Bulbs. LOL Thank for the info. Hopefully i can get the rear bumper at some point and i will most likely just order the LED harness. I have the factory trailer wiring with the 4 and 7 pin plugs so i can plug it in the 4 pin and leave it forever and if i ever needed 4 pin trailer wiring i have a 7 to 4 adapter any way. Thanks again, I would love to buy something sooner as you seem to have an amazing talent but good things come to those who wait.
GCSRT8
Discussion Starter #5
No problem. If you aren't big on adapters, I can also build my harness with a "pass-thru" on it. Meaning you can leave the harness plugged in but it will also have a 4-wire connector coming off of it to plug in to. It's up to you, I just wanted to let you know that it is in option if you would prefer it.
2005 Grand Cherokee
Thats cool. I dont think id need the adapter, as of right now anything i tow is 7 way any way.
Thanks again!
GCSRT8
Discussion Starter #7 (Edited)
Okay guys, I have one of these harnesses that has been sitting around waiting for a new owner for over two months. It is all boxed up, ready to ship. It is the LED version. Because I am getting tired of looking at it, I'm willing to let it go for $100 shipped. That's 20% off!
Let me know if you're interested.
GCSRT8
Discussion Starter #9 (Edited)
do you know if the 2006 laredo has a trailer harness?
If you are asking if Laredo's came standard with the trailer wiring, that's a question I don't have a definitive answer to. I would say that if it has a trailer hitch, it probably has the towing package option and thus would have the wiring. However, that is purely speculation.
Quickest thing to do is pop your head underneath there. The wiring will be hanging out (literally, lol) just to the left of the centerline of the vehicle.
1 - 9 of 9 Posts
