Tried the good ol search function, got some info just not anything definitive.
Has anyone successfully modified their Laredo's or Limited to use the Overland headlights?
From the research I've done thus far, the molex connectors are different between the two. Would it be easier to buy the entire front end harness which probably isn't cost effective or can you use the existing connection and change the harness?
Also, on eBay I've notices AFS vs non AFS headlights. No idea on what the difference is. Thoughts there as well?
Thank you for the help in advance.
