1 - 2 of 2 Posts
You heard right - exclusive deal for the JEEP FORUMS! This won't last!!
Listing:
Discount Code:
JP20
20% off our Dual Fog LEDs - these are not a novelty but insanely bright and these fogs are meant to light up the road.
You do not have to choose between white or yellow light on the road - you can have it both with our Fogs.
-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe (this is NOT a yellow cover over a bulb - the actual diodes create hyper yellow 3k or clean white)
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-Super HYPER YELLOW Technology - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Great for safety, daily use on dark roads and bad weather.
- Strobe and flash is a fun feature at any car show
*Please note:
-these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
-there is an option for resistors on the drop down menu if you feel your car will trigger errors - these trigger errors
-some car models with auto-headlights need to be shut off in order to avoid having fogs switch colors - some car models do not have an issue - this depends on how voltage is being sent to the fogs (sometimes with auto-headlights enabled random voltage is sent to the fogs)
Video of each color:
Demo Video:
Discussion Starter · #2 ·
1 - 2 of 2 Posts
