1 - 17 of 17 Posts
Please see attached photo. Any way to make this look better short of a new wheel?? Do I have to worry about tire weakness as it appears some nearby rubber came off? Sucks to have something on my new 2014 already :(
The Negotiator
See if you have any wheel repair companies in the area would be my suggestion.
It will be difficult to fix perfectly. Id probably try to find a paint or something similar to rub into the wound that would make it less noticeable.
Then id get the tire inspected to make sure it is ok.
Summit
Something like this happened to me this weekend as well on my 2013 WK2 with 20" Summit wheels. I am waiting to hear back from two shops to see about refinishing. I think my damage looks worse to the rim. Luckily the tire has no damage at all.
I will post pictures later of the damage and of the after if I get it repaired.
Does suck, I have only 1800 miles on my Jeep since October and this just kicks you in the nuts doesn't?
Limited
There are a few posts out here where guys have had this repaired. You may want to search for these posts, but from what I recall the repairs looked good.
2016 RAM
You want to see bad?? This happened to me a month or so ago when I got my WK2 stuck in mud.
I fixed them by using an airbrush and some Wurth paint.. Its the only paint that matches 100% to our rims.
Summit
Holy crap man. that is bad. Here is mine looks like a love tap compared to yours lol
Alloy wheel Wheel Tire Rim Automotive tire
WOW seeing that made me feel a LITTLE better (although still feel incompetent that I let my wheel hit brick coming out of my own driveway. I am not used to the extra width compared to my 2005 yet...)
Ducati Monster S2Rd
I bet that made an awesome sound when you were gunning it. :lol:
'12 ram 4d 4x dually
All Alloy Wheel Repair...depending on where you live. My neighbor has the franchise in my area, I don't have a before pic, but I hit a concrete curb parking on my factory 20's, deep scratches and removed a little metal, he fixed it up for $105. He had to do a little grinding, no filler, etch prime, paint and clear. He said he's done a lot of straightening the jeep 20's, and he said they seem almost as bad as BMW wheels(he's at the local BMW weekly doing them), but I live in pothole ridden NE Ohio. He even re-did the whole wheel because he didn't like the way it turned out. I'm very anal about the car, I can't tell he did any repair.
i had the wheel on my 2012 summit repaired by a mobile wheel repair company out of tampa they came to my house and did the repair almost looks like new for 75.00,they have many franchised wheel repair companies out there.
2012 Grand Cherokee Limited 5.7
WoW now that's a scratch :eek: thanks for the paint tip
2012 Grand Cherokee
Hi,
you had mentioned the wheel paint for the 20in alloys is very close matched to the silver paint by wurth. Did you paint the entire rim, or only the damaged areas?
You couldn't tell the difference to the original paint? How easy would it be to blend in the paint if you were to paint over the damaged areas?
Did you clear coat(type) over the entire rim?
Cheers
1 - 17 of 17 Posts
