1 - 9 of 9 Posts
I have a 2001 Grand Cherokee. I recently let a friend borrow it for a couple of weeks while their car was being repaired. Now mine needs repair and I can't figure it out. The security system keeps going off every time you turn the key. The only way to stop it is to unhook the battery. There is no working remote. I only had one, and it just stopped working about two years ago. I've been using the key to unlock the doors ever since. I tried buying a complete (used) set consisting of the computer, the SKIM module, key switch and key. Did not help problem at all. The engine will turn over but will not crank. The battery is good. I'm at a loss. Any ideas how to correct this? Its been sitting for about 4 months now, and if I don't get it cranked soon, I"m afraid the fuel system will be ruined. PLEASE HELP! And advice or suggestions would be greatly appreciated. Thank you.
You can order a pcm for 100-125 with IMMOBILIZER removed or deactivated all you do is give them your vin they will write it to pcm send to you and you unplug IMMOBILIZER from ignition then plug com in and good to go ive done it on all 3 of my jeeps and have not had a problem since just dont plug IMMOBILIZER in once new pcm is installed. All computer resources is a good company or there are a few others as well.
Thanks for the information. I was going to go that same route, but wanted to be sure it would work properly. Like I said in my post, I bought a cop\mplete used set (PCM, SKIM module, igntion switch and key) from a place on ebay and it still did the exact same thing. Wasted $100 bucks, but I'm over that. Just didn't want to "waste" any more. How sure are you this will fix my problem? No worries, I won't blame you, HAHA! I just like having second opinions. Thanks!
The beast from Brazil
To understand your problem well, what do you mean with that the security system goes off every time you want to start and you have to reset with a battery disconnect? The car alarm?
It doesn't start at all, or just for a moment and then shuts off?
Discussion Starter #5
Yes, the alarm goes off (flashing lights, honking horn). And the engine turns over but it will not run at all, not even a second. And the only way to stop the alarm is to unhook the battery.
Did you check all the fuses?
Discussion Starter #7
No, not all of them. I did manage to find the one for the security system, but the fuse was fine.
Yes, it could be as simple as that. But that the alarm doesn't disarm is probably a problem with the arm/disarm switch in the drivers door lock mechanism. The alarm doesn't sound if you open the door? Only when trying to start?
The alarm system itself should't cause the no start problem though. The immobilizer system also shouldn't prevent it from starting, but the engine would shut down after a few seconds of operation.
Since it doesn't even start, i would check the fuses first: In the PDC under the hood the fuses F6 (30A), F16 (15A), F19 (10A) and F24 (20A) and on the junction block under the dash fuse F12 (10A).
If you put the ignition switch to RUN, but don't start, does the alarm already sounds? If not, do you hear the fuel pump prime for a few seconds and then shut off? The noise level is quite low, so maybe a helper can listen at the fuel fill opening while you switch the ignition in RUN.
1 - 9 of 9 Posts
