1 - 2 of 2 Posts
Rear passenger side tail light and back up lights do not work, but brake light does on that side. My mechanic told me strong odds the master fuse junction box needs to be replaced, but the part is discontinued by Jeep. So I am looking for used ones online/at junk yards.
The exact part # for mine is 56010350AH but I am having trouble finding that exact one to match, but finding lots of others that say they come off an 01 with matching engine/transmission (automatic 3-speed) - anyone know if those will still work?
Any tips or info much appreciated.
Can you tell us exactly why the mechanic thinks its a fuse box issue?
More than likely its corroded bulb sockets or a wiring issue to those lights.
I could be wrong without a wiring diagram to verify but i suspect the right and left side lights are protected by the same common fuses.
I'd pull the bulbs and inspect those light sockets (and their bulbs) that don't work for corrosion inside in those sockets before replacing the fuse box which is not a fun job.
1 - 2 of 2 Posts
