1 - 2 of 2 Posts
So the only codes i am throwing is for the o2 sensors which i am replacing today. But for some reason when i hit 3rd gear if i go below 3000rpm my motor starts to bog down and feel like it is going to stall If I force it to go up to 3000rpm or higher everything is fine. New plugs and wires last week. HELP!
2001 WJ/WG, 3.1TD VM Motori.
I'm thinking the o2 sensors might have something to do with the symptoms you describe?
The system controls for acceleration might not be receiving the range required from the o2 sensor, so it might be inducing some kind of limp mode effect?
If the o2 sensor replacement doesn't rectify, then let us know and we can all get our thinking caps on 👍
1 - 2 of 2 Posts
