1 - 8 of 8 Posts
I just recently bought a 2002 GC Overland Ed without a manual- I managed to find that online. When I went to remove the 10 CD Cartridge in back, there is no indicator lights and when I press the eject button, nothing happens. Where do I start to try to get this to work?
Thanks
Overland
I have the same problem with my 02 overland. I have not fixed it yet but what I have been told is the lense is dirty and just needs to be cleaned. There is a cleaning disc somewhere that I have never been able to find or it can be taken apart and cleaned manually. I never bothered, I just use the single disc in dash and have plans of replacing the 10 disc with something new if I ever get around to it.
Overland
i know i push a button and it pops out but iof your not getting power then it wont work. You can remove the panel and follow the power line to see if there are any breaks or check the amp underneath the back passenger seat, and/or pop out the head unit and make sure everything is plugged in. I took the whole panel and changer out once, just a couple of bolts but you need a deep socket because the nut is on a very long bolt.
Overland
i have a link that might help but it has to be checked by a moderator first, anyway go to google, type in wj overland 10 disc changer removal, the first one that pops up if from jeep forum, it says fix oem disc changer in less than five minutes
1 - 8 of 8 Posts
