My Overland has been overheating intermittently and I suspect the hyd rad fan. Previously the temp gauge would hold steady when driving, but when I stopped or slowed down, the temp would climb beyond normal. As I said this was intermittently, say once every 3-4 months. Lately though it is happening more frequently and I have noticed the fan seemed to be making more noise than usual. Here is what I have found. At idle, the fan is not turning at all. When the engine is off and I try to turn the fan by hand, it turns but with not easily. This could be normal due to it being a hydraulic motor. I disconnected the temp sensor and started it up and the fan came on at full speed. It was quite noisy, more than just rushing air. Didn't seem normal and much to loud. But again, if the fan is at full speed when engine is at higher rpms while operating, this may be a normal operating noise.
So my thoughts are that the bearings or some other internal component is binding, not allowing the fan to turn at idle. But when full hyd pressure is applied, it will operate, albeit with noise. Not knowing enough about the circuitry, I don't know it the fan relay would be suspect. I'm thinking not, as the fan will operate. Power steering resv is full.
Just looking for any ideas. Thought about buying a used fan assembly, but I could be buying the same issue just further down the road. I will have to get the check engine light reset now, so I may have them check it out. Hate to pay them for a repair I can do. Just want to know I'm fixing the problem. Thanks
