1 - 6 of 6 Posts
Been searching and found nothing.., Working on it this morning and it seems like they all went out.,I've never seen that before.,usually one or two at a time.,,but all 4? Have you guys run across something like this? Could I have cranked it up to the point they would all go out?
FYI.,Only the door speakers are out..,tweeters in the dash are working just fine.
The beast from Brazil
Does your jeep have the infinity system with the amplifier under the rear seat? Have a look if all wiring is still connected and check fuse 5 on the junction block..
Yes it does...I pulled the right rear door panel off as everything else checked out..I ran wire from the connector to an old speaker I had laying around and it worked..I just find it odd that all four door speakers would go out...
The speakers should have a 2-3 ohm resistance. You could measure them, but if it now already works with an other speaker, it seems that the speakers are the problem.
I have the opposite my fronts are dead tweeters and doors i put new and still no work, so my amp is dead
Sent from my LG-P999 using Tapatalk 2
1 - 6 of 6 Posts
