1 - 2 of 2 Posts
I own a 2006 Jeep Grand Cherokee. I cannot find my block heater cord. HELP!!
I just took a quick look at the shop manual. It looks like all the engine block heaters (if you have one) are on the passenger side of the engine under one of the cylinders, depending on what engine you have. The cord is then routed to a convenient place for it to be plugged in. I you locate the heater (again, if you have one) you can follow that wire to the plug. The following is from the manual:
An optional engine block heater is available with all models. The heater is equipped with a power cord. The cord is attached to an engine compartment component with tie-straps. The heater warms the engine providing easier engine starting and faster warm-up in low temperatures. The heater is mounted in a core hole of the engine cylinder block in place of a freeze plug with the heating element immersed in engine coolant
I hope this helps you............
1 - 2 of 2 Posts
