Aftermarket intakes, and catbacks just empty your wallet, make it drive worse than stock, and all the added noise they make gets old real quick. Save your cash for all the maintenance and fixes that the 2006 is going to need before any power adders. You would not believe the list of repairs from my 06 Overland. FWIW I've examined a K and N under the microscope (I'm a Distributor for optical, electron and atomic force scopes), and compared to a stock paper filter, the holes are huge and let much larger particles through to the combustion chamber. This is how more airflow is achieved, which is not worth the long term damage.
You can indeed make the hemi much more responsive with the right add ons. First thing to do is spend $100 on a catch can and clean the throttle body, or even better, get a Modern Muscle 85 mm taper ported TB. Then go with a CMR custom tune, Diablosport Intune is great for this.
