My 2010 liberty sports driver side marker and turn signal flickers and works intermittently. I have changed the bulb and it did not solve the issue. I am guessing it may be a ground problem but do not know where to look? Has anyone had this issue? Thanks for any advice!
Take a good look inside the bulb socket and or connector.
Most of the time its corrosion in the socket.
Depending on the bulb type if the socket contacts are spring loaded it might not be springy enough or the contacts corroded.
If the bulb style is the press in socket type, the the contacts could be corroded.
Don't know where its ground is located but take a close look at any frayed wires.
Thank you, I will check that out, much appreciated!
