I'm having issue with my WK2 (RHD, Australian) driver side window: the power window only moves up or down two inches at a time, whether or not I hold the button, or press past the one-touch detent. I believe the window switch is not faulty.
the anti-pinch on this window does not work either, the motor would keep pushing against resistance to the point of stalling when an obstacle is placed when winding up.
I removed the window motor, which can be operated by the switch, but again only turns a few turns then stops.
The window regulator is not binding, as the motor does not seem having trouble moving it
I tested with a different Door Module ("DM-FR"), which made no difference, the relay clicks all the same, so I believe the Door Module is not faulty either.
there are no error messages or warning lights on the instrument panel
I'm having trouble figuring out the source of the problem: I can only think of Regulator -> motor -> Door Module -> window switch -> what else?
a video of my symptom is here:
any help is much appreciated
