61 - 75 of 75 Posts
Google the codes as they come. The definition of the code will be displayed on the Alpha OBD app when you have a check engine light. Are you saying that you want a list of all the trouble codes?
Manufacturer Specific Codes (Jeep)
P1105
Open Or Shorted Condition Detected In The Baro Read Solenoid Control Circuit - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1192 Inlet Air Temp. Circuit Low
P1193 Inlet Air Temp. Circuit High
P1194 Incorrect Or Irrational Performance Has Been Detected For The PWM
P1195 O2 Sensor 1/1 (Bank 1, Sensor 1) Slow During Catalyst Monitor - Read Our Article on Oxygen Sensor Codes For Help With This Jeep Check Engine Light Code
P1196 O2 Sensor 2/1 (Bank 2, Sensor 1) Slow During Catalyst Monitor - Read Our Article on Oxygen Sensor Codes For Help With This Jeep Check Engine Light Code
P1197 O2 Sensor 1/2 (Bank 1, Sensor 2) Slow During Catalyst Monitor - Read Our Article on Oxygen Sensor Codes For Help With This Jeep Check Engine Light Code
P1198 Radiator Temperature Sensor Voltage Too High
P1199 Radiator Temperature Sensor Voltage Too Low
P1243 Open Or Shorted Condition Detected In The Turbocharger Surge Valve Solenoid Control - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1280 Open Or Shorted Condition Detected In The Fuel System Relay Control Circuit - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1281 Engine Operating Temp Below Acceptable Range
P1282 Fuel Pump Relay Control Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1283 Idle Select Signal Invalid
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On
P1286 Accelerator Pedal Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Controller Supply Voltage Low
P1288 Intake Manifold Short Runner Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1289 Manifold Tune Valve Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1290 CNG Fuel Pressure Too High
P1291 No Temp Rise Seen From Fuel Heaters
P1292 CNG Pressure Sensor Voltage Too High
P1293 CNG Pressure Sensor Voltage Too Low
P1294 Target Idle Not Reached
P1295 Loss Of 5 Volts To TP Sensor
P1296 Loss Of 5 Volts To MAP Sensor
P1297 No Change In MAP From Start To Run
P1298 Lean Operation At Wide Open Throttle
P1299 Vacuum Leak Found (IAC Fully Seated)
P1388 Auto Shutdown (ASD) Relay Control Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss of CMP Or CKP
P1398 PCM Is Unable To Learn The Crankshaft Position Sensor's Signal
P1399 Wait To Start Lamp Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1403 Loss Of 5 Volts To EGR Sensor - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1475 Auxiliary 5 Volt Output Too High
P1476 Too Little Secondary Air
P1477 Too Much Secondary Air
P1478 Battery Temp Sensor Voltage Out Of Limit
P1479 Transmission Fan Relay Circuit Open Or Shorted
P1480 PCV Solenoid Valve Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1480 Open Or Shorted Condition Detected In The Positive Crankcase Ventilation (PCV - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1481 EATX RPM pulse generator signal for misfire detection
P1482 Catalyst Temperature Sensor Circuit Shorted Low
P1483 Catalyst Temperature Sensor Circuit Shorted High
P1484 Catalytic Converter Overheat Detected
P1485 Air Injection Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1486 Evap Leak Monitor Pinched Hose
P1487 Hi Speed Rad Fan CTRL Relay Circuit Open Or Shorted
P1488 Auxiliary 5 Volt Supply Output Too Low
P1489 High Speed Fan CTRL Relay Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1490 Low Speed Fan CTRL Relay Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1491 Radiator Fan Control Relay Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1492 Battery Temperature Sensor Voltage Too High
P1493 Battery Temperature Sensor Voltage Too Low
P1494 Leak Detection Pump Switch or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit Open Or Shorted
P1496 5 Volt Supply Output Too Low
P1498 High speed Rad Fan Ground CTRL Rly Circuit
P1499 Open Or Shorted Condition Detected In The Hydraulic Cooling Fan Solenoid Control
P1594 Charging System Voltage Too High
P1595 Speed Control Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1598 A/C Pressure Sensor Voltage Too High
P1599 A/C Pressure Sensor Voltage Too Low
P1602 PCM Not Programmed
P1680 Clutch Released Switch Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1681 No Instrument Panel Cluster CCD/J1850 Messages Received
P1682 Charging System Voltage Too Low
P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit Open Or Shorted
P1684 Battery Disconnected Within Last 50 Starts
P1685 Skim Invalid Key
P1686 No SKIM Bus Message Received
P1687 No Cluster Bus Message
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Communication Between ECM & Injection Pump Module
P1690 Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel Injection Pump Controller Calibration Failure
P1693 DTC Detected In ECM Or PCM
P1694 No CCD Messages Received From ECM
P1695 No CCD/J185O Message From BCM
P1696 PCM Failure EEPROM Write Denied
P1697 PCM Failure SRI Mile Not Stored
P1698 No CCD Messages Received From PCM
P1699 No CCD/J1850 Messages Received From The Climate Control Module (CCM)
P1719 Skip Shift Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1740 TCC Or OD Solenoid Performance
P1756 Governor Pressure Not Equal To Target At 15-20 PSI
P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI
P1762 Governor Pressure Sensor Offset Improper Voltage
P1763 Governor Pressure Sensor Voltage Too High
P1764 Governor Pressure Sensor Voltage Too Low
P1765 Trans 12 Volt Supply Relay Control Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1830 Open Or Shorted Condition Detected In The Clutch Pedal Switch Over-Ride Relay Control - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1899 Park/Neutral Position Switch Stuck In Park or In Gear
P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
Generic OBDII Codes
P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
P0015
"B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
P0024
"B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
P0025
"B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
P0030
HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
DTC Codes - P0100-P0199 – Fuel and Air Metering
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent - see our "articles" link for additional help with these generic check engine light codes
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent - see our "articles" link for additional help with these generic check engine light codes
P0109 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent - see our "articles" link for additional help with these generic check engine light codes
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent - see our "articles" link for additional help with these generic check engine light codes
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0123 Throttle Position Sensor/Switch A Circuit High Input
P0124 Throttle Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Temperature Below Thermostat Regulating Temperature
P0129 Barometric Pressure Too Low
P0130 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0131 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0132 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0133 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0134 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0135 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0136 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0137 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0138 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0139 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0142 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0143 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0144 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0145 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0146 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0147 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0150 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0151 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0152 Oxygen Sensor Circuit High Voltage (Bank 2 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0153 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0154 Oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0155 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) - see our "articles" link for additional help with these generic check engine light codes
P0156 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0157 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0158 Oxygen Sensor Circuit High Voltage (Bank 2 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0159 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0160 Oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0161 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) - see our "articles" link for additional help with these generic check engine light codes
P0162 Oxygen Sensor Circuit Malfunction (Bank 2 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0163 Oxygen Sensor Circuit Low Voltage (Bank 2 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0164 Oxygen Sensor Circuit High Voltage (Bank 2 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0165 Oxygen Sensor Circuit Slow Response (Bank 2 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0166 Oxygen Sensor Circuit No Activity Detected (Bank 2 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0167 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 3) - see our "articles" link for additional help with these generic check engine light codes
P0170 Fuel Trim Malfunction (Bank 1) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
P0171 System too Lean (Bank 1) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
P0172 System too Rich (Bank 1) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
P0173 Fuel Trim Malfunction (Bank 2) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
P0174 System too Lean (Bank 2) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
P0175 System too Rich (Bank 2) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
DTC Codes - P0200-P0299 – Fuel and Air Metering (Injector Circuit)
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance Fault
DTC Codes - P0300-P0399 – Ignition System or Misfire
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
DTC Codes - P0400-P0499 – Auxiliary Emissions Controls
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Insufficient Flow Detected
P0402 Exhaust Gas Recirculation Excessive Flow Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay ‘A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
DTC Codes - P0500-P0599 – Vehicle Speed Controls and Idle Control System
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
DTC Codes - P0600-P0699 – Computer Output Circuit
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A’ Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P0656 Fuel Level Output Circuit Malfunction
DTC Codes - P0700-P0899 – Transmission
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Oh did you want the Body control module codes too?
U0200 – U0299 (Network communications)
U0100 – U0199 (Network communications)
U0000 – U0099 (Network electrical)
Trouble CodeFault Location
U Codes
U0001Controller area network (CAN) data bus: high speed bus/communication control module
U0002Controller area network (CAN) data bus: high speed bus - performance problem/ configuration error
U0003Controller area network (CAN) data bus: high speed bus(+)- open circuit
U0004Controller area network (CAN) data bus: high speed bus(+)- voltage low
U0005Controller area network (CAN) data bus: high speed bus(+)- voltage high
U0006Controller area network (CAN) data bus: high speed bus(-)- open circuit
U0007Controller area network (CAN) data bus: high speed bus (-)-voltage low
U0008Controller area network (CAN) data bus: high speed bus(-)- voltage high
U0009Controller area network (CAN) data bus: high speed bus (-)-shorted to data bus(+)
U0010Controller area network (CAN) data bus: medium speed bus
U0011Controller area network (CAN) data bus: medium speed bus - performance problem
U0012Controller area network (CAN) data bus: medium speed bus(+)- open circuit
U0013Controller area network (CAN) data bus: medium speed bus(+)- voltage low
U0014Controller area network (CAN) data bus: medium speed bus(+)- voltage high
U0015Controller area network (CAN) data bus: medium speed bus(-)
U0016Controller area network (CAN) data bus: medium speed bus(-)- voltage low
U0017Controller area network (CAN) data bus: medium speed bus(-)- voltage high
U0018Controller area network (CAN) data bus: medium speed bus (-)-shorted to data bus(+)
U0019Controller area network (CAN) data bus: low speed bus
U0020Controller area network (CAN) data bus: low speed bus - performance problem
U0021Controller area network (CAN) data bus: low speed bus (+) - open circuit
U0022Controller area network (CAN) data bus: low speed bus (+) - voltage low
U0023Controller area network (CAN) data bus: low speed bus (+) - voltage high
U0024Controller area network (CAN) data bus: low speed bus (-) - open circuit
U0025Controller area network (CAN) data bus: low speed bus (-) - voltage low
U0026Controller area network (CAN) data bus: low speed bus (-) - voltage high
U0027Controller area network (CAN) data bus: low speed bus (-) - shorted to data bus (+)
U0028Vehicle area network (VAN) data bus A
U0029Vehicle area network (VAN) data bus A - performance problem
U0030Vehicle area network (VAN) data bus A (+)- open circuit
U0031Vehicle area network (VAN) data bus A (+)- voltage low
U0032Vehicle area network (VAN) data bus A (+)- voltage high
U0033Vehicle area network (VAN) data bus A (-)- open circuit
U0034Vehicle area network (VAN) data bus A (-)- voltage low
U0035Vehicle area network (VAN) data bus A (-)- voltage high
U0036Vehicle area network (VAN) data bus A (-)- shorted to data bus A (+)
U0037Vehicle area network (VAN) data bus B
U0038Vehicle area network (VAN) data bus B - performance problem
U0039Vehicle area network (VAN) data bus B (+)- open circuit
U0040Vehicle area network (VAN) data bus B (+)- voltage low
U0041Vehicle area network (VAN) data bus B (+)- voltage high
U0042Vehicle area network (VAN) data bus B (-)- open circuit
U0043Vehicle area network (VAN) data bus B (-)- voltage low
U0044Vehicle area network (VAN) data bus B (-)- voltage high
U0045Vehicle area network (VAN) data bus B (-)- shorted to data bus B (+)
U0046Vehicle area network (VAN) data bus C
U0047Vehicle area network (VAN) data bus C - performance problem
U0048Vehicle area network (VAN) data bus C (+)- open circuit
U0049Vehicle area network (VAN) data bus C (+)- voltage low
U0050Vehicle area network (VAN) data bus C (+)- voltage high
U0051Vehicle area network (VAN) data bus C (-)- open circuit
U0052Vehicle area network (VAN) data bus C (-)- voltage low
U0053Vehicle area network (VAN) data bus C (-)- voltage high
U0054Vehicle area network (VAN) data bus C (-)- shorted to data bus C (+)
U0055Vehicle area network (VAN) data bus D
U0056Vehicle area network (VAN) data bus D- performance problem
U0057Vehicle area network (VAN) data bus D (+)- open circuit
U0058Vehicle area network (VAN) data bus D (+)- voltage low
U0059Vehicle area network (VAN) data bus D (+)- voltage high
U0060Vehicle area network (VAN) data bus D (-)- open circuit
U0061Vehicle area network (VAN) data bus D (-)- voltage low
U0062Vehicle area network (VAN) data bus D (-)- voltage high
U0063Vehicle area network (VAN) data bus D (-)- shorted to data bus D (+)
U0064Vehicle area network (VAN) data bus E
U0065Vehicle area network (VAN) data bus E - performance problem
U0066Vehicle area network (VAN) data bus E (+)- open circuit
U0067Vehicle area network (VAN) data bus E (+)- voltage low
U0068Vehicle area network (VAN) data bus E (+)- voltage high
U0069Vehicle area network (VAN) data bus E (-)- open circuit
U0070Vehicle area network (VAN) data bus E (-)- voltage low
U0071Vehicle area network (VAN) data bus E (-)- voltage high
U0072Vehicle area network (VAN) data bus E (-)- shorted to data bus E (+)
U0073Control module - data bus Off
U0100Data bus: engine control module (ECM) A - no communication
U0101Data bus: transmission control module (TCM) - no communication
U0102Data bus: transfer box control module - no communication
U0103Data bus: gear shift module - no communication / System relay - low signal
U0104Data bus: cruise control module - no communication
U0105Data bus: injector control module - no communication
U0106Data bus: glow plug control module - no communication
U0107Data bus: throttle actuator control (TAC) module - no communication
U0108Data bus: alternative fuel control module - no communication
U0109Data bus: fuel pump (FP) control module - no communication
U0110Data bus: drive motor control module - no communication
U0111Data bus: battery energy control module A - no communication
U0112Data bus: battery energy control module B - no communication
U0113Data bus: emissions critical control information - no communication
U0114Data bus: four wheel drive clutch control module - no communication
U0115Data bus: engine control module (ECM) B - no communication
U0121Data bus: anti-lock brake system (ABS) control module - no communication
U0122Data bus: vehicle dynamics control module - no communication
U0123Data bus: yaw rate sensor module - no communication
U0124Data bus: lateral acceleration sensor module - no communication
U0125Data bus: multi-axis acceleration sensor module - no communication
U0126Data bus: steering position sensor control module - no communication
U0127Data bus: tire pressure monitor module- no communication
U0128Data bus: parking brake control module - no communication
U0129Data bus: brake system control module - no communication
U0130Data bus: steering effort control module - no communication
U0131Data bus: power steering control module - no communication
U0132Data bus: suspension ride height control module - no communication
U0140Data bus: body control module (8CM)- no communication
U0141Data bus: body control module (8CM) A- no communication
U0142Data bus: body control module (8CM) 8 - no communication
U0143Data bus: body control module (8CM) C- no communication
U0144Data bus: body control module (8CM) D- no communication
U0145Data bus: body control module (8CM) E - no communication
U0146Data bus: gateway A- no communication
U0147Data bus: gateway 8 - no communication
U0148Data bus: gateway C - no communication
U0149Data bus: gateway D- no communication
U0150Data bus: gateway E - no communication
U0151Data bus: supplementary restraint system (SRS) control module - no communication
U0152Data bus : supplementary restraint system (SRS) control module: left - no communication
U0153Data bus: supplementary restraint system (SRS) control module: right - no communication
U0154Data bus: supplementary restraint system (SRS) occupant sensing control module- no communication
U0155Data bus: instrumentation control module - no communication
U0156Data bus: information centre A - no communication
U0157Data bus: information centre B - no communication
U0158Data bus: head up display - no communication
U0159Data bus: parking aid control module A - no communication
U0160Data bus: audible alert control module - no communication
U0161Data bus: compass module - no communication
U0162Data bus: navigation display module - no communication
U0163Data bus: navigation control module - no communication
U0164Data bus: NC control module - no communication
U0165Data bus: NC control module: rear
U0166Data bus: auxiliary heater control module - no communication
U0167Data bus: immobilizer control 'module - no communication / Engine control module - internal fault
U0168Data bus: alarm system control module - no communication
U0169Data bus: sunroof control module - no communication
U0170Data bus: supplementary restraint system (SRS) sensor A - no communication
U0171Data bus: supplementary restraint system (SRS) sensor B - no communication
U0172Data bus: supplementary restraint system (SRS) sensor C - no communication
U0173Data bus: supplementary restraint system (SRS) sensor D - no communication
U0174Data bus: supplementary restraint system (SRS) sensor E - no communication
U0175Data bus: supplementary restraint system (SRS) sensor F - no communication
U0176Data bus: supplementary restraint system (SRS) sensor G - no communication
U0177Data bus: supplementary restraint system (SRS) sensor H - no communication
U0178Data bus: supplementary restraint system (SRS) sensor I - no communication
U0179Data bus: supplementary restraint system (SRS) sensor J - no communication
U0180Data bus: automatic lighting control module - no communication
U0181Data bus: headlamp level control module - no communication
U0182Data bus: lamps control module: front - no communication
U0183Data bus: lamps control module: rear- no communication
U0184Data bus: radio - no communication
U0185Data bus: aerial module - no communication
U0186Data bus: audio unit output amplifier- no communication
U0187Data bus: digital disc player/changer module A - no communication
U0188Data bus: digital disc player/changer module B - no communication
U0189Data bus: digital disc player/changer module C - no communication
U0190Data bus: digital disc player/changer module D - no communication
U0191Data bus: television - no communication
U0192Data bus: personal computer - no communication
U0193Data bus: digital audio control module A- no communication
U0194Data bus: digital audio control module B - no communication
U0195Data bus: subscription entertainment receiver module - no communication
U0196Data bus: entertainment control module: rear - no communication
U0197Data bus: t.elephone control module - no communication
U0198Data bus: telematics control module - no communication
U0199Data bus: door function control module A - no communication
U0200Data bus: door function control module B - no communication
U0201Data bus: door function control module C - no communication
U0202Data bus: door function control module D - no communication
U0203Data bus: door function control module E - no communication
U0204Data bus: door function control module F - no communication
U0205Data bus: door function control module G - no communication
U0206Data bus: convertible top control module - no communication
U0207Data bus: moveable roof control module - no communication
U0208Data bus: seat adjustment control module A - no communication
U0209Data bus: seat adjustment control module B - no communication
U0210Data bus: seat adjustment control module C - no communication
U0211Data bus: seat adjustment control module D - no communication
U0212Data bus: steering column control module - no communication
U0213Data bus: mirror control module A - no communication
U0214Data bus: remote function actuation - no communication
U0215Data bus: door contact switch A - no communication
U0216Data bus: door contact switch B - no communication
U0217Data bus: door contact switch C - no communication
U0218Data bus: door contact switch D - no communication
U0219Data bus: door contact switch E - no communication
U0220Data bus: door contact switch F - no communication
U0221Data bus: door contact switch G - no communication
U0222Data bus: electric window motor A- no communication
U0223Data bus: electric window motor B - no communication
U0224Data bus: electric window motor C - no communication
U0225Data bus: electric window motor D - no communication
U0226Data bus: electric window motor E - no communication
U0227Data bus: electric window motor F - no communication
U0228Data bus: electric window motor G - no communication
U0229Data bus: heated steering wheel module - no communication
U0230Data bus: tailgate control module - no communication
U0231Data bus: rain sensor control module- no communication
U0232Data bus: side obstacle detection control module: left - no communication
U0233Data bus: side obstacle detection control module: right- no communication
U0234Data bus: convenience recall module - no communication
U0235Data bus: cruise control front distance range sensor - no communication
U0293Data bus: HVAC control unit- no communication
U3000 – U4000 (Control module/ Power distribution)
U2000 – U3000 (Manufacturer defined, common defination listed)
U1000 – U2000 (Manufacturer defined, common defination listed)
P0400 – U0499 (Network data)
P0300 – U0399 (Network software)
U0300Control module - internal software incompatibility
U0301Software incompatibility - engine control module (ECM)
U0302Software incompatibility - transmission control module (TCM)
U0303Software incompatibility - transfer box control module
U0304Software incompatibility - gear shift module
U0305Software incompatibility - cruise control module
U0306Software incompatibility - injector control module
U0307Software incompatibility - glow plug control module
U0308Software incompatibility - throttle actuator control (TAC) module
U0309Software incompatibility - alternative fuel control module
U0310Software incompatibility - fuel pump (FP) control module
U0311Software incompatibility - drive motor control module
U0312Software incompatibility - battery energy control module A
U0313Software incompatibility - battery energy control module B
U0314Software incompatibility - four wheel drive clutch control module
U0315Software incompatibility - anti-lock brake system (ASS) control module
U0316Software incompatibility - vehicle dynamics control module
U0317Software incompatibility - parking brake control module
U0318Software incompatibility - brake system control module
U0319Software incompatibility - steering effort control module
U0320Software incompatibility - power steering control module
U0321Software incompatibility - suspension ride height control module
U0322Software incompatibility - body control module
U0323Software incompatibility - instrumentation control module
U0324Software incompatibility - AlC control module
U0325Software incompatibility - auxiliary heater control module
U0326Software incompatibility - immobilizer control module
U0327Software incompatibility - alarm system control module
U0328Software incompatibility - steering position sensor control module
U0329Software incompatibility - steering column control module
U0330Software incompatibility - tire pressure monitor module
U0331Software incompatibility - body control module A
U0332Software incompatibility - multi-axis acceleration sensor module
U0400Invalid data received
U0401Invalid data received - engine control module (ECM)
U0402Invalid data received - transmission control module (TCM)
U0403Invalid data received - transfer box control module
U0404Invalid data received - gear shift module
U0405Invalid data received - cruise control module
U0406Invalid data received - injector control module
U0407Invalid data received - glow plug control module
U0408Invalid data received - throttle actuator control (TAC) module
U0409Invalid data received - alternative fuel control module
U0410Invalid data received - fuel pump (FP) control module
U0411Invalid data received -drive motor control module
U0412Invalid data received - battery energy control module A
U0413Invalid data received - battery energy control module B
U0414Invalid data received - four wheel drive clutch control module
U0415Invalid data received - anti-lock brake system (ABS) control module
U0416Invalid data received - vehicle dynamics control module
U0417Invalid data received - parking brake control module
U0418Invalid data received - brake system control module
U0419Invalid data received - steering effort control module
U0420Invalid data received - power steering control module
U0421Invalid data received - suspension ride height control module
U0422Invalid data received - body control module
U0423Invalid data received - instrumentation control module
U0424Invalid data received - A/C control module
U0425Invalid data received - auxiliary heater control module
U0426Invalid data received - immobilizer
U0427Invalid data received - alarm system control module
U0428Invalid data received - steering position sensor control module
U0429Invalid data received - steering column control module
U0430Invalid data received - tire pressure monitor module
U0431Invalid data received - body control module A
U0433Invalid data received - cruise control front distance range sensor
U1000SCP (J1850) Invalid or Missing Data for Primary Id
U1001SCP (J1850) Invalid or Missing Data for Primary Id
U1002SCP (J1850) Invalid or Missing Data for Primary Id
U1003SCP (J1850) Invalid or Missing Data for Primary Id
U1004SCP (J1850) Invalid or Missing Data for EEC Programming
U1005SCP (J1850) Invalid or Missing Data for EEC Programming
U1006SCP (J1850) Invalid or Missing Data for Primary Id
U1007SCP (J1850) Invalid or Missing Data for Primary Id
U1008SCP (J1850) Invalid or Missing Data for Engine Torque
U1009SCP (J1850) Invalid or Missing Data for Engine Torque
U1010SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1011SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1012SCP (J1850) Invalid or Missing Data for Primary Id
U1013SCP (J1850) Invalid or Missing Data for Primary Id
U1014SCP (J1850) Invalid or Missing Data for Primary Id
U1015SCP (J1850) Invalid or Missing Data for Primary Id
U1016SCP (J1850) Invalid or Missing Data for Primary Id
U1017SCP (J1850) Invalid or Missing Data for Primary Id
U1018SCP (J1850) Invalid or Missing Data for Throttle
U1019SCP (J1850) Invalid or Missing Data for Throttle
U1020SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1021SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1022SCP (J1850) Invalid or Missing Data for Primary Id
U1023SCP (J1850) Invalid or Missing Data for Primary Id
U1024SCP (J1850) Invalid or Missing Data for Primary Id
U1025SCP (J1850) Invalid or Missing Data for Primary Id
U1026SCP (J1850) Invalid or Missing Data for Engine RPM
U1027SCP (J1850) Invalid or Missing Data for Engine RPM
U1028SCP (J1850) Invalid or Missing Data for Primary Id
U1029SCP (J1850) Invalid or Missing Data for Primary Id
U1030SCP (J1850) Invalid or Missing Data for Experimental #1
U1031SCP (J1850) Invalid or Missing Data for Experimental #1
U1032SCP (J1850) Invalid or Missing Data for Primary Id
U1033SCP (J1850) Invalid or Missing Data for Primary Id
U1034SCP (J1850) Invalid or Missing Data for Primary Id
U1035SCP (J1850) Invalid or Missing Data for Primary Id
U1036SCP (J1850) Invalid or Missing Data for Wheels
U1037SCP (J1850) Invalid or Missing Data for Wheels
U1038SCP (J1850) Invalid or Missing Data for Primary Id
U1039SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed
U1040SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1041SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1042SCP (J1850) Invalid or Missing Data for Traction Control
U1043SCP (J1850) Invalid or Missing Data for Traction Control
U1044SCP (J1850) Invalid or Missing Data for Traction Motor
U1045SCP (J1850) Invalid or Missing Data for Traction Motor
U1046SCP (J1850) Invalid or Missing Data for Primary Id
U1047SCP (J1850) Invalid or Missing Data for Primary Id
U1048SCP (J1850) Invalid or Missing Data for Primary Id
U1049SCP (J1850) Invalid or Missing Data for Primary Id
U1050SCP (J1850) Invalid or Missing Data for Brakes
U1051SCP (J1850) Invalid or Missing Data for Brakes
U1052SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1053SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1054SCP (J1850) Invalid or Missing Data for Primary Id
U1055SCP (J1850) Invalid or Missing Data for Primary Id
U1056SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1057SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1058SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1059SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1060SCP (J1850) Invalid or Missing Data for Primary Id
U1061SCP (J1850) Invalid or Missing Data for Primary Id
U1062SCP (J1850) Invalid or Missing Data for Primary Id
U1063SCP (J1850) Invalid or Missing Data for Primary Id
U1064SCP (J1850) Invalid or Missing Data for Primary Id
U1065SCP (J1850) Invalid or Missing Data for Primary Id
U1066SCP (J1850) Invalid or Missing Data for Primary Id
U1067SCP (J1850) Invalid or Missing Data for Primary Id
U1068SCP (J1850) Invalid or Missing Data for Primary Id
U1069SCP (J1850) Invalid or Missing Data for Primary Id
U1070SCP (J1850) Invalid or Missing Data for Engine Sensors
U1071SCP (J1850) Invalid or Missing Data for Engine Sensors
U1072SCP (J1850) Invalid or Missing Data for Engine Coolant
U1073SCP (J1850) Invalid or Missing Data for Engine Coolant
U1074SCP (J1850) Invalid or Missing Data for Engine Oil
U1075SCP (J1850) Invalid or Missing Data for Engine Oil Temp
U1076SCP (J1850) Invalid or Missing Data for Primary Id
U1077SCP (J1850) Invalid or Missing Data for Primary Id
U1078SCP (J1850) Invalid or Missing Data for Primary Id
U1079SCP (J1850) Invalid or Missing Data for Primary Id
U1080SCP (J1850) Invalid or Missing Data for Primary Id
U1081SCP (J1850) Invalid or Missing Data for Primary Id
U1082SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1083SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1084SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1085SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1086SCP (J1850) Invalid or Missing Data for Primary Id
U1087SCP (J1850) Invalid or Missing Data for Primary Id
U1088SCP (J1850) Invalid or Missing Data for Suspension
U1089SCP (J1850) Invalid or Missing Data for Suspension
U1090SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1091SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1092SCP (J1850) Invalid or Missing Data for Primary Id
U1093SCP (J1850) Invalid or Missing Data for Primary Id
U1094SCP (J1850) Invalid or Missing Data for Experimental #2
U1095SCP (J1850) Invalid or Missing Data for Experimental #2
U1096SCP (J1850) Invalid or Missing Data for Primary Id
U1097SCP (J1850) Invalid or Missing Data for Primary Id
U1098SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1099SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1100SCP (J1850) Invalid or Missing Data for Primary Id
U1101SCP (J1850) Invalid or Missing Data for Primary Id
U1102SCP (J1850) Invalid or Missing Data for Primary Id
U1103SCP (J1850) Invalid or Missing Data for Primary Id
U1104SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1105SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1106SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1107SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1108SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1109SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1110SCP (J1850) Invalid or Missing Data for Primary Id
U1111SCP (J1850) Invalid or Missing Data for Primary Id
U1112SCP (J1850) Invalid or Missing Data for Primary Id
U1113SCP (J1850) Invalid or Missing Data for Primary Id
U1114SCP (J1850) Invalid or Missing Data for Charging System
U1115SCP (J1850) Invalid or Missing Data for Charging System
U1116SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1117SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1118SCP (J1850) Invalid or Missing Data for Primary Id
U1119SCP (J1850) Invalid or Missing Data for Primary Id
U1120SCP (J1850) Invalid or Missing Data for Primary Id
U1121SCP (J1850) Invalid or Missing Data for Primary Id
U1122SCP (J1850) Invalid or Missing Data for Odometer
U1123SCP (J1850) Invalid or Missing Data for Odometer
U1124SCP (J1850) Invalid or Missing Data for Primary Id
U1125SCP (J1850) Invalid or Missing Data for Primary Id
U1126SCP (J1850) Invalid or Missing Data for Primary Id
U1127SCP (J1850) Invalid or Missing Data for Primary Id
U1128SCP (J1850) Invalid or Missing Data for Primary Id
U1129SCP (J1850) Invalid or Missing Data for Primary Id
U1130SCP (J1850) Invalid or Missing Data for Fuel System
U1131SCP (J1850) Invalid or Missing Data for Fuel System
U1132SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1133SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1134SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1135SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1136SCP (J1850) Invalid or Missing Data for Telltales
U1137SCP (J1850) Invalid or Missing Data for Telltales
U1138SCP (J1850) Invalid or Missing Data for Primary Id
U1139SCP (J1850) Invalid or Missing Data for Primary Id
U1140SCP (J1850) Invalid or Missing Data for Gateway
U1141SCP (J1850) Invalid or Missing Data for Gateway
U1142SCP (J1850) Invalid or Missing Data for Primary Id
U1143SCP (J1850) Invalid or Missing Data for Primary Id
U1144SCP (J1850) Invalid or Missing Data for Primary Id
U1145SCP (J1850) Invalid or Missing Data for Primary Id
U1146SCP (J1850) Invalid or Missing Data for Vehicle Security
U1147SCP (J1850) Invalid or Missing Data for Vehicle Security
U1148SCP (J1850) Invalid or Missing Data for Audio Control
U1149SCP (J1850) Invalid or Missing Data for Audio Control
U1150SCP (J1850) Invalid or Missing Data for Audible Warnings
U1151SCP (J1850) Invalid or Missing Data for Audible Warnings
U1152SCP (J1850) Invalid or Missing Data for Experimental #3
U1153SCP (J1850) Invalid or Missing Data for Experimental #3
U1154SCP (J1850) Invalid or Missing Data for Compact Disc
U1155SCP (J1850) Invalid or Missing Data for Compact Disc
U1156SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1157SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1158SCP (J1850) Invalid or Missing Data for Antenna
U1159SCP (J1850) Invalid or Missing Data for Antenna
U1160SCP (J1850) Invalid or Missing Data for Primary Id
U1161SCP (J1850) Invalid or Missing Data for Primary Id
U1162SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1163SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1164SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1165SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1166SCP (J1850) Invalid or Missing Data for Cassette Tape
U1167SCP (J1850) Invalid or Missing Data for Cassette Tape
U1168SCP (J1850) Invalid or Missing Data for Primary Id
U1169SCP (J1850) Invalid or Missing Data for Primary Id
U1170SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1171SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1172SCP (J1850) Invalid or Missing Data for Remote Button Control
U1173SCP (J1850) Invalid or Missing Data for Remote Button Control
U1174SCP (J1850) Invalid or Missing Data for Primary Id
U1175SCP (J1850) Invalid or Missing Data for Primary Id
U1176SCP (J1850) Invalid or Missing Data for Primary Id
U1177SCP (J1850) Invalid or Missing Data for Primary Id
U1178SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1179SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1180SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1181SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1182SCP (J1850) Invalid or Missing Data for Primary Id
U1183SCP (J1850) Invalid or Missing Data for Primary Id
U1184SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1185SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1186SCP (J1850) Invalid or Missing Data for Primary Id
U1187SCP (J1850) Invalid or Missing Data for Primary Id
U1188SCP (J1850) Invalid or Missing Data for Primary Id
U1189SCP (J1850) Invalid or Missing Data for Primary Id
U1190SCP (J1850) Invalid or Missing Data for Primary Id
U1191SCP (J1850) Invalid or Missing Data for Primary Id
U1192SCP (J1850) Invalid or Missing Data for Primary Id
U1193SCP (J1850) Invalid or Missing Data for Primary Id
U1194SCP (J1850) Invalid or Missing Data for Mirrors
U1195SCP (J1850) Invalid or Missing Data for Mirrors
U1196SCP (J1850) Invalid or Missing Data for Door Locks
U1197SCP (J1850) Invalid or Missing Data for Door Locks
U1198SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1199SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1200SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1201SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1202SCP (J1850) Invalid or Missing Data for Windows
U1203SCP (J1850) Invalid or Missing Data for Windows
U1204SCP (J1850) Invalid or Missing Data for Steering Column
U1205SCP (J1850) Invalid or Missing Data for Steering Column
U1206SCP (J1850) Invalid or Missing Data for Primary Id
U1207SCP (J1850) Invalid or Missing Data for Primary Id
U1208SCP (J1850) Invalid or Missing Data for Seat Switches
U1209SCP (J1850) Invalid or Missing Data for Seat Switches
U1210SCP (J1850) Invalid or Missing Data for Restraints
U1211SCP (J1850) Invalid or Missing Data for Restraints
U1212SCP (J1850) Invalid or Missing Data for Primary Id
U1213SCP (J1850) Invalid or Missing Data for Primary Id
U1214SCP (J1850) Invalid or Missing Data for Primary Id
U1215SCP (J1850) Invalid or Missing Data for Primary Id
U1216SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1217SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1218SCP (J1850) Invalid or Missing Data for External Lamps
U1219SCP (J1850) Invalid or Missing Data for External Lamps
U1220SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1221SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1222SCP (J1850) Invalid or Missing Data for Interior Lamps
U1223SCP (J1850) Invalid or Missing Data for Interior Lamps
U1224SCP (J1850) Invalid or Missing Data for Primary Id
U1225SCP (J1850) Invalid or Missing Data for Primary Id
U1226SCP (J1850) Invalid or Missing Data for Body Status Request
U1227SCP (J1850) Invalid or Missing Data for Body Status Request
U1228SCP (J1850) Invalid or Missing Data for Tires
U1229SCP (J1850) Invalid or Missing Data for Tires
U1230SCP (J1850) Invalid or Missing Data for Electric Defrost
U1231SCP (J1850) Invalid or Missing Data for Electric Defrost
U1232SCP (J1850) Invalid or Missing Data for Navigation
U1233SCP (J1850) Invalid or Missing Data for Navigation
U1234SCP (J1850) Invalid or Missing Data for Displays
U1235SCP (J1850) Invalid or Missing Data for Displays
U1236SCP (J1850) Invalid or Missing Data for Memory Storage
U1237SCP (J1850) Invalid or Missing Data for Memory Storage
U1238SCP (J1850) Invalid or Missing Data for Experimental #4
U1239SCP (J1850) Invalid or Missing Data for Experimental #4
U1240SCP (J1850) Invalid or Missing Data for Primary Id
U1241SCP (J1850) Invalid or Missing Data for Primary Id
U1242SCP (J1850) Invalid or Missing Data for Exterior Environment
U1243SCP (J1850) Invalid or Missing Data for Exterior Environment
U1244SCP (J1850) Invalid or Missing Data for Interior Environment
U1245SCP (J1850) Invalid or Missing Data for Interior Environment
U1246SCP (J1850) Invalid or Missing Data for Primary Id
U1247SCP (J1850) Invalid or Missing Data for Primary Id
U1248SCP (J1850) Invalid or Missing Data for Time / Date
U1249SCP (J1850) Invalid or Missing Data for Time / Date
U1250SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1251SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1252SCP (J1850) Invalid or Missing Data for Class A Functions
U1253SCP (J1850) Invalid or Missing Data for Class A Functions
U1254SCP (J1850) Invalid or Missing Data for Network Control
U1255SCP (J1850) Invalid or Missing Data for Network Control
U1260SCP (J1850) Single Ended (+) Circuit Failure
U1261SCP (J1850) Single Ended (-) Circuit Failure
U1262SCP (J1850) Communication Bus Fault
U1308SCP (J1850) Invalid or Missing Data for Function Read Engine Torque
U1341SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed
U1417Implausible Left Wheel Distance Signal (Dodge, Chrysler, Jeep)
U1430SCP (J1850) Invalid or Missing Data for Function Read Fuel System
U1451SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings /Anti-Theft Module
U1612SCP (J1850) Lack of Acknowledgment for Primary Id
U1736SCP (J1850) Lack of Acknowledgment for Telltales
U1750SCP (J1850) Lack of Acknowledgment for Audible Warnings
U1794SCP (J1850) Lack of Acknowledgment for Mirrors
U1797SCP (J1850) Lack of Acknowledgment for Door Locks
U1798SCP (J1850) Lack of Acknowledgment for External Access (Doors)
U1806SCP (J1850) Lack of Acknowledgment for Primary Id
U1900CAN Communication Bus Fault
U1950UPB Communication Bus Fault
U2000Audio Rear Control Unit is Not Responding
U2001Audio Tape Deck Unit is Not Responding
U2002Audio Bezel is Not Responding
U2003Audio Compact Disk / Disk Jockey Unit is Not Responding
U2004Audio Steering Wheel Control Unit is Not Responding
U2005Audio Rear Integrated Control Panel Unit is Not Responding
U2006Audio Remote Climate Control Unit is Not Responding
U2007Audio Navigation Unit is Not Responding
U2008Audio Phone is Not Responding
U2009Audio Front Control Module (ACM) is Not Responding
U2010Module is Not Responding (Non SCP)
U2011Module Transmitted Invalid Data (Non SCP)
U2012Communication Bus Error (Non SCP)
U2013Compass Module is not Responding
U2014Audio Subwoofer Unit is Not Responding
U2015Signal Link Fault (Non SCP)
U2016Signal Link Short to Ground (Non SCP) / From NGV Module
U2017Driver Side Crash Sensor Communication Fault (Non SCP)
U2018Passenger Side Crash Sensor Communication Fault (Non SCP)
U2019Audio Voice Module Not Responding
U2020Audio Center Amp is not responding
U2021Invalid /fault data received (Non SCP)
U2150SCP (J1850) Invalid Data from REM
U2152SCP (J1850) Invalid Data from GEM
U2160SCP (J1850) Invalid Data from IC
U2195SCP (J1850) Invalid Data from SCLM
U2500(CAN) Lack of Acknowledgement From Engine Management
U3000Control Module
U3001Control Module Improper Shutdown
U3002Vehicle Identification Number
U3003Battery Voltage
U3004Accessory Power Relay
U3005Retained Accessory Power
U3006Control Module Input Power "A"
U3007Control Module Input Power "B"
U3008Control Module Ground "A"
U3009Control Module Ground "B"
U300AIgnition Switch
U300BIgnition Input Accessory/On/Start
U300CIgnition Input Off/On/Start
U300DIgnition Input On/Start
U300EIgnition Input On
U300FIgnition Input Accessory
U3010Ignition Input Start
U3011Ignition Input Off
U3012ISO/SAE Reserved
U3100ISO/SAE Reserved
Or do this
Or do this
Thanks for the link, much easer to work with. I appreciate your patientance with my ignorance on this matter.
You can also buy Foxwell NT530 loaded with Chrysler software for around $150. Makes for easy forced Regen.
$50 you can add other auto manufacturers specific software, up to four manufacturers on unit.
Unit also comes with generic code reading, for all auto makes.
Glad it worked for you. Alpha OBD can do all sorts of cool things beside the DPF regen, but that feature alone makes it worth the money. Any time you can avoid the suck festival that is the dealership, is a win in my book.
Which is better, the OBDlink Mx or AlphaOBD?
OBDlink MX is the Bluetooth adapter that plugs into the OBD port. AlphaOBD is the software (App) that connects to the adapter
Sorry meant to say the OBDLink software that comes with the MX, not the dongle. Since then I see that AlphaOBD is for FCA vehicles, so that answers my question. One other question, in selecting the vehicle model for the AlphaOBD setup I assume the correct selection for my 2014 Grand Cherokee diesel would be Grand Cherokee (WK2) My2011> ?
Correct
61 - 75 of 75 Posts
