Re: 2014 GC Summit Fener Flares
6 figure cars also use double sided tape.
Sorry this happened to you, but 3m double sided tape has been an industry standard for over a decade.
Sounds like you got some contaminant on the drivers side before the tape was installed. As long as they properly prep with alcohol, you'll be fine.
Thks for the reply.
Noted -> "6 figure cars also use double sided tape." I'm curious, do you work for Jeep/Chrysler in ANY capacity (even via a 3rd party)?
Pls advise which 6 figure cars use double sided tape, and
pls specify the exact application/location on those cars where double sided tape is used in an
EXTERIOR application. If you make such a statement, I assume you know the exact details/replies to those simple questions, and can reply as quickly as you did with the first reply. Then, I'd like to speak to those manufacturers to confirm.
Noted -> "Sounds like you got some contaminant on the drivers side before the tape was installed."
Did all of the other people having the same problem also have "some contaminant" on their cars?
Noted -> "As long as they properly prep with alcohol, you'll be fine." I hope you are correct.
Appreciate your reply.
