Hey all, I've tried searching the forum for similar questions but none turned up helpful responses.
Yesterday I changed the oil on my 2014 Jeep Grand Cherokee diesel. After completing the oil change I let the vehicle sit overnight, and in the morning started it up - but after a few seconds the engine shut down, and a low oil pressure warning showed up. I tried starting it a few more times, thinking it might just need some priming, but got the same results. Any help is appreciated - more details below.
My oil change details -
Removed engine cover, loosened full cap, removed drain plug, while waiting for drain I removed the air intake hose and replaced oil filter and o-ring (K&N PS-7042) torqued cover back to 25.5 NM. Reinstalled drain plug, filled with 8qts of oil (Rotella t6 5w-40). Reinstalled the air intake hose, reinstalled the engine cover Reset oil change reminder.
The next day - check the oil level on dipstick - around the 'max' line, despite about 7-8qts drained. Started up engine then experienced shutdown. I removed the oil filter, and it's covered in oil inside and out. I then reinstalled the filter.
