1 - 20 of 646 Posts
Are you thinking of upgrading your 2014 Grand Cherokee's headlights to HID with an HID kit but are unsure of what to expect?
We recently received some great feedback from forum member tvguy710 who recently installed the XenonDepot 5000k HID Kit in his 2014 Grand Cherokee and was kind enough to post up some pictures and provide feedback. The 2014 Cherokee uses H11 bulbs for the low beams meaning that you would need to order an H11 HID kit if you are considering this upgrade. While Jeep has changed the headlights on the 2014 the overall installation and parts required are the same for 2011+ model year Jeep Cherokee. Here is what you would need to get:
1) Xtreme HID Kit and select the H11 fitment. If you are unsure about which color temperature to select, keep in mind that 4300k will provide you with the closest output to stock HID lighting and the higher you go in terms of color temperature the less actual useable light output you will get. Please view this HID Kit Buying Guide for more info.
2) You will have to use a relay harness and capacitors or HID Kit error code eliminators when upgrading your headlights to HID. The Xtreme kit will come with a relay harness however you will also need to order the error code eliminators to prevent any sort of flickering or error codes being thrown when the kit is installed.
3) The XenonDepot H11 Xtreme HID kit will be plug+play. The kit will come with proper H11 connectors that will plug into your vehicle's OEM H11 headlight harness and will not require you to cut, tap, or splice any wires.
This customer chose to remove his headlights in order to install the kit which unfortunately required bumper removal. In some cases, customers have reported that they were able to access the headlights by removing the fender liner and accessing the headlights from the back (2011, 2012, and 2013 models).
Check out the pictures below to see some pictures of the 5000k HID kit installed in factory 2014 Jeep Cherokee halogen projector headlights.
Danny
Looks awesome!
Quick quesiton...
I had some a 6000K HID Kit installed on my 2014 Laredo (replaced halogen low beams)
Sometimes the HID will work, and sometimes they will not turn on.
They also will not turn on with the automatic on/off setting for the headlights.
My question is, will the error code eliminator fix this problem?
Thanks in advance.
SRT8
Looks awesome!
Quick quesiton...
Thanks in advance.
Did you Install a Relay Kit and Canbus Fixes?
Okay, thank you so much!
Just to be clear, the dash instrument panel will act normal and show that the headlights are turned on.. but the headlights themselves are not actually illuminated.
I will order the fix and have the shop throw them on and let you know how it goes.
Thanks again
jesuswalks239: It could also be the HID kit that you have installed. The Xtreme HID kit has low draw ballasts. I have seen some issues with HID kits that do not have low draw ballasts when used in "Auto mode"
Steve
Thanks Steve. I just contacted the shop I had the lights installed at and I will be having them remove the kit. After that I plan on ordering from XenonDepot. Question, do I still have to order the Canbus fix with the Xtreme HID Kit ($169 option) And also is the 6500K close to 6000K? I like a pure white with a light hint of blue.
Thanks again for your help.
Discussion Starter · #9 ·
Hi,
Yes, you would need to order the CANBUS fix as well. I would suggest going with 5000k if you want a pure white with a very very very slight bluish tone.
Steve
What about for the fogs? They are projectors right? Would they too respond well to an HID kit?
Discussion Starter · #18 ·
Hi,
Definitely go for the Xtreme kit as the ballasts have a lower starting draw which means they will work properly when used in "auto"mode.
If you only want a slight bluish tinge I would suggest looking at the 5000k kit.
Steve
Hey Steve,
I placed my order last week, thanks for your help! Unfortunately, both the H11 5000K and the can-bus fix are back ordered. Do you have any idea how long this could take before it's shipped out?
Thanks
1 - 20 of 646 Posts
