1 - 20 of 13971 Posts
Administrator
Production start date: Late March 2013
Sales launch date: July 2013
Models (2WD/4WD):
Laredo
Laredo E
Limited
Overland
Summit (fall 2013)
SRT
Engines:
3.0L CRD
3.6L Pentastar
5.7L Hemi
6.4L Hemi
Transmissions:
8-spd 845RE (3.6L)
8-spd 8HP70 (3.0L, 5.7L, 6.4L)
RHD 4WD Laredo 3.0L CRD - features list (preliminary)
(note - some features may be optional)
12V Auxiliary Power Outlet
18X8.0 Polished Aluminum Wheels
195MM Front Axle
220 Amp Alternator
230MM Rear Axle
24.6 Gallon Fuel Tank
240 KPH Primary Speedometer
3.0L Diesel Badge
3.0L V6 Turbo Diesel Engine
3.45 Rear Axle Ratio
4X4 Badge
6 Speakers
8.4 Touch Screen Display
800 Amp Maintenance Free Battery
8-Spd Auto 8HP70 Trans
Accent/Body Color Fascias
Active Head Restraints
Advanced Multistage Front Air Bags
Air Cond ATC w/Dual Zone Control
Air Filtering
All Aluminum Wheels
All Automatic Transmissions
Anti-Lock 4-Wheel Disc HD Brakes
Australia Equipment Group
Auto High Beam Headlamp Control
Automatic Headlamp Leveling System
Automatic Headlamps
Auxiliary 12-Volt Rear Power Outlet
BI-Xenon HID Headlamps
Body Color Door Handles
Body Color Exterior Mirrors
Body Color Grille w/Bright Inserts
Body Color Shark Fin Antenna
Bright Day Light Opening Moldings
Bright License Plate Brow
Bright Side Roof Rails
Capless Fuel Filler
Cargo Compartment Cover
Cargo Tie Down Loops
Cargo Trim Panel w/Storage Net
Center Rear 3-Point Seat Belt
Child Seat Anchor System-LATCH Ready
Child Seat Upper Tether Anchorages
Cigar Lighter
Cloth Low Back Bucket Seats
Conventional Differential Frt Axle
Conventional Differential Rear Axle
CORA Tire Press Monitoring Sensor
Diesel Particulate Filter (DPF)
Disable 4-Low Speed Restriction
Drvr Inflatable Knee-Bolster Air Bag
Dual Bright Exhaust Tips
Dual Note Electric Horns
Elec. Steering Column Shaft Lock
Electro-Hydraulic Power Steering
Electronic Stability Control
Engine Oil Cooler
Enhanced Accident Response System
Euro Stage 5 Emissions w/EOBD 5
Ext. Mirrors w/Supplemental Signals
Exterior Mirrors w/Heating Element
Exterior Spotter Mirrors
Four Wheel Drive (4WD)/(4X4)
Four Wheel Traction Control
Front Rear Interior LED Lamps
Front Door Tinted Glass
Front License Plate Bracket
Front Passenger Seat Belt Alert
Full Length Floor Console
Full Size Spare Tire
Glove Box Lamp
GPS Antenna Input
Grand Cherokee Badge
Headlamp Washer
Heated Front Seats
Heavy Duty Engine Cooling
Hill Descent Control
Hill Start Assist
Hood Insulation
Illuminated Cupholders
Illuminated Entry
Integrated Liftgate Rear Spoiler
Integrated Voice Command w/Bluetooth
Interior Removable/Rechargeable Lamp
Jeep Badge
Keyless Enter-N-Go
Laminated Front Door Glass
Laredo Badge
Leather Wrapped Shift Knob
Leather Wrapped Steering Wheel
LED Daytime Running Headlamps
LED Tail Lamps
Luxury Front/Rear Floor Mats w/Logo
Luxury Group
Michelin Brand Tires
MOPAR Splash Guards
Moroccan Sun Interior Accents
Normal Duty Suspension
Overhead Console
P265/60R18 BSW AS On/Off Rd Tires
Passenger Assist Handles
Passive Pedestrian Protection Delete
Power 8-Way Driver/Passenger Seats
Power Accessory Delay
Power Folding Mirrors
Power Folding Multi-Function Mirrors
Power Locking Fuel Filler Door
Power Locks
Power Rack and Pinion Steering
Premium Fog Lamps
Premium Instrument Cluster w/Tach
Premium Insulation Group
Pwr Driver/Pass 4-Way Lumbar Adjust
Pwr Front Windows, 1-Touch,Up Down
Quadra-Trac II (R) 4WD System
Rain Brake Support
Rain Sensitive Windshield Wipers
Ready Alert Braking
Rear 60/40 Folding Seat
Rear Fascias Parts Module
Rear Fog Lamps
Rear Load Leveling Suspension
Rear Window Defroster
Rear Window Wiper/Washer
Remote Keyless Entry
Remote Proximity Keyless Entry
Remote SD Card Slot
Remote USB Port
Removable Ash Tray
RHD Optics Headlamps
Right Hand Drive
RR View Auto Dim Mirror w/Microphone
Security Alarm
Selec-Terrain System
Sentry Key Theft Deterrent System
Sill Molding
Smoker's Group
Speed Control
Steel Spare Wheel
Steering Wheel Mounted Audio Ctrls
Steering Wheel Mounted Shift Control
Sun Visors w/Illum Vanity Mirrors
Supp. Side Curtain Frt/Rr Air Bags
Supplemental Frt Seat Side Air Bags
Supplemental Side Air Bags
Tilt/Telescope Steering Column
Tinted Rr Drs/Qtr/Liftgate Glass
Tinted Windshield Glass
Tip Start
Tire Pressure Monitoring Display
Tow Eye Brackets
Trailer Sway Damping
Trailer Tow Prep Group
Uconnect 8.4 AM/FM/BT
Uconnect Voice Command w/Bluetooth
Vehicle Information Center
RHD 4WD Limited 5.7L - features list (preliminary)
195MM Front Axle
20X8.0 Aluminum Wheels
220 Amp Alternator
230MM Rear Axle
265/50R20 BSW All Season Tires
3.09 Rear Axle Ratio
4X4 Badge
5.7L V8 MDS VVT Engine
506 Watt Amplifier
700 Amp Maintenance Free Battery
9 Amplified Speakers w/Subwoofer
Air Filtering
Auto Dim Exterior Driver Mirror
Auto Dim Exterior Passenger Mirror
Automatic Headlamps
Body Color Fascias w/Bright Insert
Bright Door Handles
Capless Fuel Filler
Cigar Lighter
Deep Tint Sunscreen Glass
Dual Remote USB Port - Charge Only
Engine Oil Cooler
Euro Stage 6 Emissions
Exterior Mirrors Courtesy Lamps
Exterior Mirrors w/Memory
Glove Box Lamp
GPS Antenna Input
Headlamp Washer
Heated Front Seats
Heated Second Row Seats
Heated Steering Wheel
Hill Start Assist
Hood Insulation
Illuminated Entry
Jeep Badge
Keyless Enter-N-Go
Kumho Brand Tires
LED Tail Lamps
Limited Badge
MOPAR Splash Guards
Overhead Console
ParkSense FT/RR Park Assist System
ParkView(TM) Rear Back-up Camera
Passive Speed Limiting Device
Power Liftgate
Power Locks
Power Tilt/Telescope Steering Column
Prem Leather Trimmed Bucket Seats
Premium Door Trim Panel
Premium Fog Lamps
Pwr 8-Way Drvr Mem 8-Way Pass Seats
Radio/Driver Seat/Mirrors Memory
Rain Brake Support
Ready Alert Braking
Rear Fog Lamps
Remote SD Card Slot
Remote USB Port
Removable Ash Tray
Security Alarm
Sill Molding
Single Disc Remote CD Player
Smoker's Group
Speed Control
Steel Spare Wheel
Tip Start
Tow Eye Brackets
Uconnect 8.4N AM/FM/BT/NAV
RHD 4WD Overland 5.7L - features list (preliminary)
195MM Front Axle
220 Amp Alternator
230MM Rear Axle
4X4 Badge
506 Watt Amplifier
Advanced Brake Assist
Advanced Technology Group
Air Filtering
All Aluminum Wheels
Automatic Headlamps
Blind Spot and Cross Path Detection
Bright Door Handles
Bright Grille
Capless Fuel Filler
Cargo Net
Cigar Lighter
Deluxe Security Alarm
Door Courtesy Lamps
Door Parts Module
Dual-Pane Panoramic Sunroof
Elec LTD Slip Differential Rr Axle
Engine Oil Cooler
Enhanced Adaptive Cruise Control
Export Tuned Suspension
Forward Collision Warning Plus
Glove Box Lamp
GPS Antenna Input
GVW Rating - 6500#
Headlamp Washer
Heated Front Seats
Hill Start Assist
Hood Insulation
Illuminated Entry
Jeep Badge
Keyless Enter-N-Go
Kumho Brand Tires
Leather Trim Seats w/Edge Welting
Leather Wrapped I/P Center Armrest
LED Tail Lamps
Luxury Door Trim Panel
MOPAR Splash Guards
Overhead Console
Overland Badge
ParkView Rear Back-up Camera
Power Liftgate
Power Locks
Premium Fog Lamps
Quadra-Drive II 4WD System
Quadra-Lift Air Suspension
Rain Brake Support
Ready Alert Braking
Rear Fog Lamps
Remote SD Card Slot
Remote USB Port
Removable Ash Tray
Right Hand Drive
Sill Molding
Smoker's Group
Standard Duty Engine Cooling Delete
Steel Spare Wheel
Tip Start
Tow Eye Brackets
Under Seat Lighting
Ventilated Front Seats
Wood/Leather Wrapped Steering Wheel
RHD 4WD Summit - features list (preliminary)
19 Speakers High Performance Audio
195MM Front Axle
20X8.0 Aluminum Polished Wheels
220 Amp Alternator
230MM Rear Axle
4X4 Badge
825 Watt Amplifier
8-Speed Auto 8HP70 Trans
Adaptive Bi-Xenon HID Headlamps
Advanced Warning/Adaptive Cruise Ctl
Air Conditioning ATC w/Dual Zone Control
Air Filtering
Automatic Headlamps
Body Colour Exterior Mirrors
Body Colour Fascias w/Bright Insert
Body Colour Shark Fin Antenna
Bright Door Handles
Bright Grille / Fog Lamp Bezels
Capless Fuel Filler
Cargo Net
Chrome Bodyside Molding
Cigar Lighter
Door Courtesy Lamps
Driver Inflatable Knee-Bolster Air Bag
Engine Oil Cooler
Exterior Mirrors w/Supplemental Signals
Front & Rear Interior LED Lamps
Glove Box Lamp
GPS Antenna Input
GPS Navigation
Headlamp Washers
Heated Front Seats
Hill Start Assist
Hood Insulation
Illuminated Entry
Jeep Badge
Keyless Enter-N-Go
Kumho Brand Tires
LED Tail Lamps
Overhead Console
Power Liftgate
Power Locks
Premium Fog Lamps
Protective Coating and Remover
Power 8-Way Driver Memory 8-Way Passenger Seats
Power Driver/Passenger 4-Way Lumbar Adjust
Power Front Windows, 1-Touch, Up/Down
Rain Brake Support
Ready Alert Braking
Rear DVD Entertainment System (optional)
Rear Fog Lamps
Remote SD Card Slot
Remote USB Port
Removable Ash Tray
Rear View Auto Dim Mirror w/Microphone
Sill Molding
Single Disc Remote CD Player (optional)
Smoker's Group
Steel Spare Wheel
Steering Wheel Mounted Audio Controls
Steering Wheel Mounted Shift Controls
Summit Badge
Tip Start
Tow Eye Brackets
Under Seat Lighting
RHD SRT8 - features list (preliminary)
195MM Front Axle
2014 Vehicle Specifications
20X10.0 Polished 5 Spoke Wheels (Standard)
20X10.0 Satin Carbon Split 5 Spoke (optional)
220 Amp Alternator
230MM Rear Axle
295/45ZR20 BSW All Season Tires
3.70 Rear Axle Ratio
300 KPH Primary Speedometer
506 Watt Amplifier (Standard)
825 Watt Amplifier (Optional)
6.4L V8 SRT HEMI MDS Engine
9 Amplified Speakers w/Subwoofer (Standard)
19 Speakers High Performance Audio (Optional)
Active Damping Suspension
Air Filtering
All Aluminum Wheels
Anti-Lock 4-Wheel Disc Perf Brakes
APAC Region ROW
Automatic Headlamps
Black Grille
Black Roof Molding
Body Color Sill Extension
Bright Exhaust Tip
Bright Pedals
Capless Fuel Filler
Cigar Lighter
Daytime Running Headlamps, Dedicated
Driver Passenger Lower LED Lamps
Engine Oil Cooler
Full Length Flr Console Prem A/Rest
Glove Box Lamp
GPS Antenna Input
GVW Rating - 6500#
Headlamp Washer
Heated Front Seats
High Perform Suspension
High Speed Engine Controller
Hill Start Assist
Hood Insulation
Illuminated Entry
Instr. Cluster w/Perf Display Screen
Jeep Badge
Keyless Enter-N-Go
Leather Trim Seats w/Preferred Suede
Leather Wrapped Upper Door Trim
LED Tail Lamps
Overhead Console
Performance Tuned Steering
Pirelli Brand Tires
Power Liftgate
Power Locks
Premium Fog Lamps
Quadra-Trac Active On Demand 4WD
Rain Brake Support
Ready Alert Braking
Rear Fog Lamps
Rear Suspension Damper Parts Module
Rear Suspension Parts Module
Remote SD Card Slot
Remote USB Port
Removable Ash Tray
Right Hand Drive
Run Flat Tires
Seat Parts Module
Selec-Trac System
Silver Anodized Interior Accents
Smoker's Group
Sport Mode
SRT8 Badge
Steel Spare Wheel
Tip Start
Tow Eye Brackets
Under Seat Lighting
Wheel Flare Extension Kit
-Milous
Does production date have any correlation with launch dates, I.e. should we know more around the same timeframe?
Administrator
Discussion Starter #5
Yes, hopefully Jeep Australia will release information by the time production gets rolling.
Thanks Milous. Do we in Australia presume the difference between Overland and Summit will be the same as in the US? Regards Brian
great ! thanks Milous..
If time permits can you add Overland spec as you know it? we currently get Advanced Safety and Quadra Drive II standard on Overland and hopefully it stays that way and they don't dilute the current spec and force buyers into the Summit which will probably be over AU $80K
Administrator
Discussion Starter #9
I believe that those options will be like what is in the U.S., optional or part of a package.
Milous, by any chance are you in a position to post the specs for the internal colour combinations for both Overland and Summit. I was wanting light beige with deep brown on the dash, top of door trims and deep brown carpet etc but was told could only get black with the light frost/beige upholstery......but the dealer was referring to an Overland. They still have no clues of the Summit coming and would have no idea of the Summit specs you have posted above. You probably are aware we spell colour with a "u" and grille with an "e".
Milous, another matter....the wording "Body colour fascia w/bright insert"....is that the wording that means the grille will have the chome or bright coloured honey comb type insert. I ask that question because our previous top model only had black plastic inserts which was the only thing that was different from the American Overland-Summit.
Administrator
Discussion Starter #14
From what I know so far, the colours are the same as US spec.
Administrator
Discussion Starter #15 (Edited)
The "insert" wording refers to the fascia insert (lower). Pretty certain grille will be same as U.S., with chrome around slots and chrome honeycomb insert - but I have not seen pics yet or detailed specs.
Milous Can you help us??
Has production of the MY 2013 finished as indicated in this forum? Our Sales Person in Aus told me yesterday it is still in production. We ordered a Laredo with the Off-Road Adventure 11 Pack - Quadra Lift and Quadra Drive at end of December. The big question is.....what will we get......the MY 2013 as ordered or have to change to the 14 ??
Hi Pattyann, i've been facing the same dilemma as you. Based on the feedback of Milous and other forum members whether you get a My13 or MY14 will depend on what your dealer received in the last shipment of MY13's. Order banks for mY13 have long since been closed and unless your dealer has one in stock or due to arrive in your spec then you will most likely have to wait for a MY14. They won't be able to order you one contrary to what they might say.
Administrator
Discussion Starter #18
2013 model year Grand Cherokee production ended in mid-January. Order banks closed in October for the U.S. and in November for some of the other markets. I truly doubt that your dealer could have placed an order to the factory for a 2013 at the end of December. The plant was shut down the first week of January, leaving less than two weeks to finish off existing orders.
Your dealer probably took your deposit to get the immediate sale, and will probably soon come up with a "story" to buy time to switch you over to a '14. Or perhaps he has some '13's that were ordered before the deadline and will try to sell you one of those or try and get one from another dealer. IF you had a legitimate order for the 2013 you "ordered", you/your dealer would have received a VON/VIN by now.
The "insert" wording refers to the fascia insert (lower). Pretty certain grille will be same as U.S., with chrome around slots and black honeycomb insert - but I have not seen pics yet or detailed specs.
Milous, sorry but need further clarification. I thought the Summit had chrome honeycomb inserts and the black honeycomb was on the Overland?.....and did you (and all you Aussies out there) note my post 10077 in the other main forum (features & changes). The dealer has been working hard to find out about whether we are getting the Summit in addition to the Overland but the advice he has received from head office is directly opposite to what you have advised. He has been a very helpful person (far more obliging than other salesmen) and I do believe he is being very open and helpful so does that mean head office is changing their plans back to only an Overland for Australia? And if that is the case we then have to speculate whether it will look like a US Summit or US Overland. Just to throw some confusion into the ranks of all Aussies here:confused::confused::eek:
