I intend to exchange my 2011 GC headlamps into 2014.
Has anyone a wiring diagramm of the connector?
What year and trim level are you planning to install these into?
Which model 2014 headlights were you considering?
There are a couple of unknowns.
1. Will they physically fit and match with the grille (no one has reported back on this as yet)
2. Will you have swap out the entire front bumper and grille
The 2014 halogen housing now has a four pin single row molex connector to power the low beam.
The the turnsignal, highbeam and sidemarker are still the same. So if someone was considering updating the front end of a 2011-2013 to a 2014 it would not be that hard to make the adapter for the halogen to halogen swap.
Okay onto the 2014 Bixenon.
The headlight uses a 16 pin molex connector the feeds all the functions, such as low beam, high beam, LED DRL, LED turnsignal and LED sidemarkers
One thing to note the on the headlight there is no amber park light it uses the LED DRL at a lower intensity as the park light.
Swapping these headlights into a 2014 laredo requires:
Adapting all the separate plugs into the single 16 pin per side.
Adapting a DRL harness to control the LED DRLs
