1 - 20 of 28 Posts
Hi all,
I have on order a JCG Overland with 18" wheels, as you all know the main spare comes in a steel rim as well as a smaller tire. (even though all say full size spare) Any way, what I am looking at doing if anyone has any suggestions. as I don't have a vehicle in town to inspect for ideas until I get mine
I have purchased another genuine 18" wheel (still chasing a TPM to suit car, any help on that would be great to :)) when car gets here I am having all 4 wheels and the new wheel fitted with Cooper AT3's. Then I plan to mount one spare in well bay,Hopefully the alloy will fit here and the other one hopefully the steel mount under the vehicle as there seems to be a large area and have found pics of wheels mounted here before. This way as we live remote and travel remote I can carry and have 2 spares at all times.
Have attached a photo of what I found below :eek:
Cheers :thumbsup:
To be honest I really have no idea, and wont have any idea until I get myine here next year to work on that to see if possible, I am hoping it is. Google images can only supply me limited details lol. to have a car to view and meaure everything and see where to bolt it would be awesome, but not even our dealer has one in stock :-(
Is there really enough room underneath, without compromising your ground clearance?
Not only the size but as well as load rating... see below
4 x MAIN
Michelin latitude tour tyres P265/60R18 109T
Max Load 2271P / 1030KG
Speed 190km
1 x SPARE
Kumho Solus KR21 P245/65R18 109T
Max Load 1984P / 900KG
Speed 190km
I suppose they get away with it as it is a full size and not one of those crap space savers???
well worded I guess??
SO what size is the "not full" full size spare?
This seems very misleading and sneaky by Jeep.
Is it the same overall diameter, just narrower?
· Lifer: Old Geezer
Overland
Try googling online Mopar sensors--or a local tire/wheel store. Swapped to winter wheels a bit ago, and totally seamless, and didn't even complain for the 5 miles or so when the factory sensors and the aftermarket wheels with Mopar sensors were in/on the vehicle.
· Lifer: Old Geezer
Overland
4 x MAIN
Speed 190km
1 x SPARE
Speed 190km
Those sizes do seem to offer an option for the OP if they can locate good tires where a 235 to 245 width in a 60-70 size are available--as long as the outer diameter matches to avoid drive train strain if the spare ever has to be used. This presumes that the Kumho is a piece of unacceptable garbaj, which it may not be. Surprised it has the same speed rating. I've traded a jeep at 19 years and the cheapo spare was still where it was when new. Luck...
An ome alloy 18 with a full size tyre, to match the four on the car WILL fit under the rear cargo area floor - just! It depends on the brand of tyre. I have an ome alloy with an ome Kuhmo tyre and the floor just closes with a bit of a push. I think the bridgestones are a bit squarer and fit a bit better.
I'm impressed by that photo - how did they get the GC to hover in the air like that?
· Premium Member
2017 Summit
Thanks for the post. I forgot that they don't use the same OEM tyres down under.
Hi all,
Cheers :thumbsup:
Interesting picture - my MY12 doesn't look anything like that??
Kev.
Discussion Starter · #14 ·
Kev.
Hi kev
Yes very different, wonder if 14 is different or same? I guess i will have to wait till mine is here to have a good look under it to work that soare out.
Cheers
Discussion Starter · #18 ·
I agree, i am totally confused whats what now, need to finda. 2014 jgc and take photos to proof it lol.
I'm confused. Looks like a WK2 to me - a petrol 6. What do you think is different?
Well I think the most obvious is the trail arms on the original pic that shellhall posted, that looks like a WH/WK. The multilink suspension on the rear can be seen in Kev's picture, I think that is what takes up the extra space. The rear axle is different, and the exhaust.
edit: what would be interesting is to compare an ML350 underbody with the wk2....
Hi all,
Cheers :thumbsup:
If you use this space for an extra tyre you cannot use it for an extra fuel tank.
I would rather have extra fuel for towing and put the extra tyre on the roof or elsewhere.
1 - 20 of 28 Posts
