Hello, i have a Jeep Grand Cherokee 2014 overland and it recently has been giving me electrical problems. The dashboard lights flicker and messages pop up for example, “Auto park disabled” & “Low voltage battery”. Can anyone help me out?
How old is your battery?
If you are not sure, take it to an Autozone, Advance Auto or other parts store and have them do a load test on the battery. It sounds like a battery issue.
Thank you! I’ll do that. I’m hoping that’s the issue and will keep you updated
JGC
If you take it to Advance Auto, be sure to first go to their website and look at their Platinum AGM battery. They'll then send you a 20% off coupon code. No sense paying their retail.
It could also be a loose/corroded/bad ground or battery terminals. I'd check the battery cables, clean them and the battery post regardless and tighten them. If that doesn't work start looking under the dash and the hood for grounds and do the same thing for them.
