1 - 9 of 9 Posts
'22 JGC 4xe & '14 JGC LTD; '09 Subaru Forester; RIP '05 Subaru Legacy STI EVO
Quick question about the heated steering wheel in our cars. I have a 2014 Limited with the optional packages. My steering wheel is LEATHER and heated.
Is the steering wheel supposed to heat up uniformly 360 degrees or not? Mine is heated up all around, but the upper part, 10 o'clock to 2 o'clock (if you wish) is considerably warmer than the rest of the "doughnut". Is this something that the rest of you can confirm or you all have nice toasty warmth all around?
Thanks.
Thanks.
I have a '14 GC Limited also, and haven't noticed any difference in heating. Maybe it's heated uniformly, but since your hands are mostly between 10&2, the rest of the wheel is radiating heat better, and not getting as hot? I notice with the heated seats, for example, that they don't feel nearly as warm, until you're sitting on them, containing the heat. Your mileage may vary :)...
alright, what about you folks with Overland and Summit trims with wood-lined steering wheels. Is your warming up uniformly? Thanks.
The heated steering wheel on my 2014 Overland has several areas that get warmer then others. Just figured it's caused by either the transfer medium or a series of small heaters located around the wheel. Either way its an option I don't think I could give up now, I like it.
· Lifer: Old Geezer
Overland
No.
I notice two areas which are consistently hotter than the rest.
The fake woodgrain area at the top and the leather covered area right at the very bottom.
The 2 and 10 position is sorta where the naked woodgrain transitions to leather so I'd expect to feel some difference in apparent warmness there, but it is by far from the hottest area of the wheel.
Haven't taken actual contact measurements, just using bare hands on frigid mornings.
1 - 9 of 9 Posts
