What I'm expecting to happen is... if the seat was moved around, either by myself or the Memory 2 user, when I come back to my car and unlock it using the key fob it will return to my preset automatically (without hitting the door button).
Even using the above instructions, it still doesn't do this. I must hit the door 1 button to return to my preset.
Anyone else get this working correctly? Or are my expectations wrong?
Problem solved (my wife actually solved it for me!)
Updated manual has correct instructions for 2014 JGC:
http://www.jeep.com/en/owners/manuals/
(Page 165-166)
Linking And Unlinking The Remote Keyless Entry
Transmitter To Memory
Your RKE transmitters can be programmed to recall one
of two pre-programmed memory profiles by pressing the
UNLOCK button on the RKE transmitter.
NOTE: Before programming your RKE transmitters you
must select the “Memory To FOB” feature through the
Uconnect® system screen. Refer to “Customer- Programmable
Features — Uconnect® Access 8.4 Settings ” in
“Understanding Your Instrument Panel” for further information.
To program your RKE transmitters, perform the following:
1. Remove the Key Fob from the ignition (or change the
ignition to OFF, for vehicles equipped with Keyless
Enter-N-Go).
2. Select desired memory profile (1) or (2).
NOTE: If a memory profile has not already been set,
refer to Programming The Memory Feature for instructions
on how to set a memory profile.
3. Once the profile has been recalled, press and release
the SET (S) button on the memory switch, then press
and release button (1) or (2) accordingly. “Memory
Profile Set” (1 or 2) will display in the instrument
cluster on vehicles equipped with the EVIC.
4. Press and release the LOCK button on the RKE
transmitter within 10 seconds.
NOTE: Your RKE transmitters can be unlinked to your
memory settings by following steps 1-4 above and pressing
the UNLOCK button (instead of LOCK) on the RKE
transmitter in Step 4.
UPDATE - Tip: Make sure you don't hit UNLOCK on the fob shortly after completing the linking. Doing so can undo the link per the NOTE above.
