Oh and on the overland it should be the Quadra Drive II system
The Quadra-Drive® II active, full-time 4WD system is the ultimate for virtually any driving situation. This system uses the Quadra-Trac II® transfer case with an Electronic Limited Slip Differential in the rear axle, offering excellent tractive performance. Quadra-Drive II also features a 2.72 low range and neutral.
When to use:
High range:All road surfaces, including wet or snow-covered pavement, sand or gravel.Low range:Conditions requiring added low-speed power, technical driving, and situations when added torque is helpful (e.g. pulling a boat trailer out of water).
Available on these 4x4 vehicles
- Limited
- Overland
- Overland Summit
Details
Quadra-Trac II® is an active, full-time 4WD system that functions in 4WD until additional traction is needed. It then reacts by electronically engaging the clutch pack to transfer up to 100% of the torque to either axle. The system works with the Brake Lock Differential and Four-Wheel Brake Traction Control systems to deliver confident all-weather traction. The Quadra-Trac II 4WD system also features a 2.72:1 low range and neutral for flat towing.
When to use:
- Virtually any driving situation
Standard on these 4x4 vehicles
- Limited
- Overland
- Overland Summit
Detailsbuild & price
Details
