Status
Not open for further replies.
41 - 60 of 638 Posts
Discussion Starter · #42 ·
I dont normally drive with the cabin lights on, they only come on when you manually turn them on or you open the door.
· Premium Member
I wonder if the fog bulb is the same on the summits.
· Premium Member
will have to try and figure out what bulb type this is , if you want to replace it.
The bulb is an H11 same as a the SRT8
· Premium Member
Yep
· The Negotiator
So can you get the H11 in a LED?
I can confirm it's h11 on the 2014. I ordered some h16's and took the bulb out to be surprised.
Is it a standard 55w bulb? It's much easier finding H11 bulbs compared to H16's
Discussion Starter · #53 ·
the v-led order is not in yet, but you can pre-order them. as soon as I get my order i can post up some pics, should be here mid april.
Discussion Starter · #56 · (Edited)
Received confirmation last night that the fogs shipped , will post up pics this weekend hopefully. Also just aside note , to replace the passenger side headlight bulb you need to remove 2 wire harnesses in order to reach the bulb housing , I was able to do this with no tools and replace the bulb- it's a little tricky cause you can only see with your fingers
You can reach the fog lights by using the same method , just feel with you hand underneath the front bumper and pull out / replace
Discussion Starter · #58 · (Edited)
OMG either v-leds sent the wrong bulb or the picture on their website is wrong for the bulb type. I just got mine in the mail today and it was the STRAIGHT type again... i emailed the seller to see what the mix up was. on a lighter note i replaced the vanity bulbs and I got the glove box bulb out, but I think I will have to take apart the glove box in order to get the new bulb in.
correct bulb that I ordered (so i think)
BULB THEY SENT ME
L shape bulb original, and the 1st order I got the wrong bulb -- anyone else know where to order this bulb if vleds doesnt have it?
Discussion Starter · #59 ·
I also have to replace my passenger side headlamp again, since that bulb only lasted about a week. Some of you need help doing this, so I will take a video of it and post it up. as for the fog lights, when I find out more I will update the thread again.
Status
