I know this doesn't help, but curious as to why you want to remove it?
This seems like WAY too much work, money, and time, for what? Aesthetics?Was thinking i needed to see a exploded view of the center console too. My idea is to get the shift dial from the Ram and replace shifter in the GC. Would have to do some studying but i dont think it wold be hard to just build a mounting plate that sits in original shifter opening.........
How touchy is the shifter? I've always rested my hand on the shifter as well and was worried that the 14 shifter would be too touch for this. I don't want to be constantly shifting it into neutral....This seems like WAY too much work, money, and time, for what? Aesthetics?
I think the dial with a filler plate would look much worse than the shifter.
My first few vehicles in life were manuals, so my hand is always on any shifter. The shifter in the '14 is really comfortable and gives me something to rest my hand on. I would hate having the dial in the Ram.
Not touchy at all....that won't happen. You'd have to bump into it really good in order to shift into neutral... definitely not by resting or moving your hand on/around it.How touchy is the shifter? I've always rested my hand on the shifter as well and was worried that the 14 shifter would be too touch for this. I don't want to be constantly shifting it into neutral....
I leave my hand on the shifter all the time. It's not an issue. You'd have to knock the shifter pretty good to even think about bumping it into neutral.Not touchy at all....that won't happen. You'd have to bump into it really good in order to shift into neutral... definitely not by resting or moving your hand on/around it.
In order to shift into an actual gear, you need to depress the button.
Because even though my WK2 went through a so called Quality Assurance Test (see my post elsewhere) where they also put about 28 miles on my WK2, they didn't put the center console cover around the shifter back on properly. And also the little storage compartment (usb/sd card) in front of the shifter also isn't installed properly. I rather repair it myself then have the dealer attack it. But I might have to go back since the centering of the steering wheel is off so it sounds like a wheel alignment is in order. JoyI know this doesn't help, but curious as to why you want to remove it?
So, you haven't paid any attention to the 2014 Durango thread I see.I doubt the Durango will get it since it's a Dodge product and not a Ram product. The Charger which is a Dodge product has the same style as the Jeep.
I try to stay away. We wanted a Durango originally and if I find I like the update, I will end up hating myself for jumping the gun on the 2014 JGC updateSo, you haven't paid any attention to the 2014 Durango thread I see.![]()
