Hello, i have cut the part. But in the future i want remove all for install the front protection Cheif production (this WK2 Lower Front Guard)Hi
Sorry to open old thread but this one had many experts.
What about removing only the lower cover (6CK19TZZAA) for more ground clearance when offroading. The amount of clearance gained is accessible for me. So, how easy remove it and will it expose critical parts for potential damage.
Thanksyes after cutting, the lower part can be removed by turning those clips you ask for. If you don't want to cut you can unhook the hooks underneath and remove all the clips from the bumper as indicated in the manual when you have to go off road.
Nice Looking.
That's look interesting, do you have the link of this thread. I appreciate it.As far as I know it is not removable on Summit / High Altitude model and it maybe holding up the sensor / grill. There is a fellow Jeeper with a High Altitude that cut the bottom part off but left the plastic brackets on.
Sorry no thread or link in Jeep Garage. This was someone from the Facebook wk2 forum (months ago)Tha
Thanks for the info.Sorry no thread or link in Jeep Garage. This was someone from the Facebook wk2 forum (months ago)
Great details and photos.There has been quite a few posts on the tow hook installations, but I wanted to add in some details, options and techniques I used on my HA in case it came in handy for someone. I know the posts here have helped me enormously as I have taken on different projects or just wanted to figure something out.
This is for my 2015 HA tow hook installation -Part I
• Started by removing the airdam and splashield.
• Some of the fascia 16 clips are easy to remove, others are more difficult.
• I made a panoramic picture of the clips locations. I pried the fascia away with a 2x4 to get the most difficult ones.
• Once the clips were out, I worked the fascia down and out until free.
• I detached the lower fascia grill from the fascia so I could work with it more easily.
• I tried a variety of techniques to cut the grill including a coping saw (very clean), utility knife, fine saw blade, dremel butane knife (couldn’t get hot enough), and a utility knife mounted to the dremel butane that I heated with my propane torch (this worked the best, just kept reheating the blade).
