Wow, I wish that were true for me. The issue is non-stop for me. When you take the weak contrast ratio, add sun glare, have the sunroof open, and then put on sunglasses, it basically means it is impossible to read the screen.
Can anyone confirm if the new Uconnect 2014 model is an LED type screen (AMOLED?) In the photos the contrast looks vastly improved, but all the photos I've seen so far look like they were not taken in direct sunlight.
Nobody takes pictures of their screens in direct sunlight. I think you've probably got the brightness setting down, my 430N has quite high contrast.
That said, with my polarized sunglasses, I can move my head to a position where it blacks the screen out some. It's tough and involves leaning forward and tilting and such (found it wile trying to reach into the back).
AMOLED is a Samsung proprietary technology, so you're definitely not going to get that (also, it basically winds down to being a special LED backlight). LED is the same as LCD, just with a different source of backlighting. Standard LCDs use a normal bulb, LED displays use LEDs to backlight an LCD screen.
It's possible your unit just has a bad bulb (ie warranty issue). I drove with my roof open back in sunny South Florida and had no issues seeing the 430N, despite direct sunlight that was very intense.
