Randomly when I press the start button to turn the engine on it takes several seconds to turn over and start. Most of the time it fires up normally, but this hard starting occurs maybe every 5th to 10th time. This is a brand new 2014 Overland V6 with 600 miles on it.
I've checked the grounding wire, it is firmly attached. I found most of the fuses to be not all the way pushed in, but the problem still persists.
Any other suggestions to check before bringing it in? I do hear short durations of a small electric motor/actuator sound when the Jeep is parked in my garage and turned-off. Not sure if this is the air suspension checking itself or something else. It seems to be coming from the component that is mounted just behind the front bumper on the passenger side.
Thanks! Eric
Thanks! Eric
