TH owner here, lots of offroading, crawling granite and technical stuff. Do not lift your TH, at most buy the front-only leveling link (96.5mm ball to ball on my DIY one). Obviously you don't need all 4 to level the car. 32" do tend to rub. I have the Sahara wheels/tires. I also needed a spacer to clear the caliper and run here and there. Worth it though.
Contrary to popular belief, lifting your car will make it handle worse, you'll lose extension and thus ability to keep wheels on the ground offroad. I rarely use OR1 and much less OR2 while offroad unless i'm trying to clear a boulder under the car. I've even put the car into parking mode going down a rather tight and steep bank, also at dragon's tail on hells revenge, just to keep wheels on the ground.. "adding suspension" ; |
I do wish QL had more rebound damping to it, its pretty underdamped IMO.
