1 - 18 of 18 Posts
2017 Altitude
Hi,
I'm new here. Just leased my 2017 Jeep Grand Cherokee Altitude edition.
I'm wondering, did the headlights on this model change from previous years or is it just different trims have different headlights?
Basically, I see Jeep Grand Cherokees on the road with the halo, white neon headlights. Wondering if that was a certain year or trim, maybe I have it on my ride but doesn't seem like I do when I checked my headlights .
Thanks, love the new Jeep.
JGC Altittude
Those are only on the Limited and above trims. Since the Altitude is based on the Laredo, its never come whith the leds from the factory. Doesnt mean it cant be done and many have retro fitted those leds to the MY17. Pricey though.
2017 Altitude
Ok cool. Thank you for the info. I'll probably stick to what I have. It works fine.
- Full custom harness is needed if you have halogen lights.
- New Image Autosports in Arlington, TX did this one below. Guess they have a custom wire harness.
- Have no idea how much it cost lol. Welcome to the forum!
2013 Lexus GS350
This member did her conversion using Jeep_addicted harness. He's a member here. I also did the same on my 17 GC Altitude. It is a pricey mod. I installed it myself. The other option would be a HID kit in your current headlights.
I'll second that - if you're looking for the best upgrade from stock halogen lighting, an H11 HID Conversion Kit would be the way to go for your Grand Cherokee.
Just make sure you get one with some sort of Canbus Fix (PWM module, Error Canceller - everyone calls them different names) because you will need something more than a basic kit due to the Daytime Running Lights sharing that same H11 Low Beam bulb.
~Robert
JGC Altittude
So after a few months of constant issues with my HID's i went back to my shop that installed them and since i have insurance on them seems they have a new ballast for 2017 and up vehicles that includes the canbus, anti flicker or error canceller. So far its good, but what i have done is turned the DRL feature off and will operate them manual instead of auto. Will report back after some time. Hopefully these work well for some time.
On another note, the headlights on the Altitude and maybe the MY17 Laredo's look great even with the halogen bulbs. Not sure if they are projector lens but the output of the lens and bulb are not too bad and lood good compared to other vehicles and their lens. So worst case scenario i'll switch back. Agreed OEM HIDS are much better and far less hassles lol. Should have switched out my headlights on the 2014 i had...lol.
I just bought a brand new 2017 black altitude and love it. The projector headlights a great even though I really wish I had the factory hid and dlr's. I pretty much gave up trying to find a pair of headlights on eBay, just seems like no seller has the pair. Not to mention the whole upgrade would be $1200+. I've come down to just upgrading the yellowish color/temp bulbs to give it a more "premium" look but unfortunately my jeep didn't come with a manual. Can someone please point me to the right direction with the bulbs sizes (high,low and fogs) or/and give some advice. Thanks.
2013 Lexus GS350
Whenever you're ready to do the upgrade let me know. I make a custom harness that is plug and play. it requires no cutting, slicing or drilling and you'll be able to go back to halogen system when your lease is up.
Is your harness different then Jeep_addicted?
Where did you get the harness? And how much
He (Ziras) makes them. I just received mine this past Tuesday and it is truly plug and play. In fact, the hardest part was figuring out where I wanted to mount the plastic junction box. Im OCD with that stuff so it probably took me longer than the average installer lol. Ziras is the man! He was always quick to respond to my questions, even late at night. I bought the harness from here (Ziras does not sell them direct): https://www.mhfautolighting.com/collections/conversion-harnesses/products/halogen-to-hid-harness
15 Grand Cherokee
I have a 2015 Altitude with the halogen headlights to which i converted over to the higher end srt style headlights. i went on ebay and found a matching pair from a 2017 for $650. And then i had to purchase the Ziras harness which indeed works perfectly. It was true plug n play aside from having to mount 4 resistors for the led turn signals in those headlights. Also they function with the turn signal where the led ribbon goes out until the turn signal is kicked off(during day driving). My most favorite upgrade i did.
220325
hey if i message you would you be willing to answer a few questions about how you did this? currently in the process of doing it myself
2019 Grand Cherokee Altitude
Very simple to do this just expensive. I also converted to the OEM HID lamps on my ‘19 Altitude. I purchased the lamps and harness (Ziras) from MHF Autolighting.com. You’ll need to remove the front bumper cover. Then remove the halogen lamps, install the harness (plug and play except I fabricated two aluminum brackets to mount the resistors on each side of radiator support). Then plug the harness into you’re new lamps and reinstall the bumper cover. I’ve had mine in since the middle of August with no issues. They work just like OEM and can be controlled through the U connect lighting settings.
1 - 18 of 18 Posts
