I have a 2019 Cherokee Trailhawk Elite that I purchased used last summer with approximately 22,000 miles. It is in very good well maintained condition but shortly after getting it I discovered a strange issue with the power liftgate. Every so often when I grab the door handle to unlock it the liftgate would beep and it would automatically go up. This would not happen every time but over the course of several months I have identified some trends about this issue. Here is a summary of what I have learned.
Has anyone else had this type of issue? Would love to hear your thoughts.
- First of all it does appear to be related to outside temperature. When it is above 80F outside it is more likely to occur. Also, if the liftgate is facing the sun it is more likely to occur. Over the cooler seasons and through the winter it never happens, ever.
- It can be triggered in different ways. The following actions have triggered this event; Grabbing the door handle to unlock it, Unlocking using the key fob, when driving it won’t open but does beep and display the message to “place in park to operate liftgate”. While driving it has randomly triggered but also has when using a turn signal or when the auto off feature starts the engine. Again, only when hot.
- Things I have tried to fix this; change batteries in key fobs, deactivated the foot operation of the liftgate, deactivated the auto unlock of the door when grabbing the handle. Pulling the #50 fuse for the power liftgate resolves the issue but makes it impossible to open.
- When the Jeep is not running it will activate once and then seem to behave, I can’t just lock the Jeep again and recreate it. But if I am driving it seems to be more unstable for the first 10 minutes or so until temperatures get cooled off.
