1 - 7 of 7 Posts
I just purchased a Certified Pre-owned 2020 Grand Cherokee Limited 4WD and I'm wanting swap out the stock headlights for some Bi-xenon LED headlights.. I'm not sure if I should be buying it with the harness kit or without. I was browsing this website(link below). Do I have to buy the headlights with or without the harness kit?
headlights with harness kit- 2014-2021 Jeep Grand Cherokee Bi-Xenon LED Headlamps
without- 2014-2021 Jeep Grand Cherokee Bi-Xenon LED Headlamps
also, does anyone know if this website is any legit?
anyone out there with some pointers and can direct me, I'd appreciate it, thanks in advance :D !!
2014 GC Limited 4X4
You will definitely NEED the harness and yes that website is legit, BUT some have had issues with their products or customer service or both. Do your research before committing that kind of money.
2019 Grand Cherokee Altitude
I converted from the stock halogen lamps to the OEM Bi-xenon lamps using the lamps and harness from MHF. As stated above you definitely need the conversion harness. I have not had any issues with the quality of the lamps or the harness. I installed mine back in August 2019. The performance of the lamps far exceed the OEM halogen. My results below:
2019 Grand Cherokee Trailhawk
Yikes that's a lot of money. They must be really good.
Yeah it’s not cheap by any means. When I bought my 2019 Altitude the bi-Xeon lamps were not available on Laredo based trims. Starting in 2020 they became optional on Laredo X and above for I believe $750.00. To me the OEM halogen lamps were so poor it made it worth it to spend the money to upgrade.
Discussion Starter #6
1 - 7 of 7 Posts
