2011 wk2
Newbie here...Anyone have these in their wk2... ours is a 2011 stock Laredo..... almost new for 400$. Will they fit no issues... any help would be greatly appreciated!
That tire size pushes the limits as they are 32.1" in diameter and ~32" is pretty much the limit without physical modification of the vehicle. You'll also need to find a fifth tire of the same diameter for your spare if you have a 4x4...
2011 wk2
Thanks...it’s actually 5 tires for $400. But with what you said, I’m hesitant to purchase... it just was a good deal on the tires..and I need some?
You also have the issue of your speedo and odo will no longer be accurate... ;)
I had 255-70/18's previously, which work out to the same size and were wrangler sahara take offs. They fit without any issue and any other modifications. I'd say go for it if you are interested, it's a decent deal. Speedo will be off a little as mentioned above but really not a big deal, it works out to a few MPH.
