Is there an easy way to make my 2018 High Altitude 5.7 crank a little before letting it start? Sometimes it sits for a few days and I'd like to get some oil pressure going before it fires up. I thought that I read somewhere if you hold the accelerator all the way down, while you push on the brake and push the button it will just crank. .......I just tried that and that works apparently with no ill effects. If anyone has reason to believe that doing that will cause any kind of problem,please let me know.
I just did a little more experimenting and it seems like the engine will just crank while the accelerator is depressed and once you let it up the engine starts. That would work for me in cases where the Jeep sat for more than a few days. Any input is welcome
Thanks
Save Share
Reply Quote
Thanks
Save Share
Reply Quote
