1 - 6 of 6 Posts
What is the difference between #5 and #6 seat cushion on the JGC line. Just what are they talking about?
No idea what you are talking about. You're going to have to provide a little more to go on.:confused:
When I "build" a JGC, the items list gives Limited with a #6 seat foam cushion, Overland #5 and Summit #3. I don't know if this refers to thickness, density, or something else altogether.
Jeep wk
Dont all the seats have a different logo on them, or color?
Honda Odessey
Just replaced my cushion with the SRT one, so I guess your numbers refer to the parts diagram. Not sure which diagram you are referring to but there are three or four different cushion and much more covers:
- regular cushion (no cooling)
- regular cushion (cooling, there is some space cut out for it)
- SRT (different sides, higher and cut out for the cooling)
All cushions fit to the same frame, only the frame for backrest is different each time.
'10 Nissan Maxima SV
Iirc seat cushion numbers corresponds to the cushion firmness. The base MY14 Limited has a #6 Seat Foam Cushion while the LuxII Package uses #1 Seat Foam Cushion which folks report to be firmer
1 - 6 of 6 Posts
