1 - 14 of 14 Posts
1999 Jeep WJ
4.0L Straight Six
I know, everyone is probably saying "Oh man, not another low oil pressure thread" but this has a solution.
I recently rebuilt my engine and have yet to put many miles on it. (working on it little by little to get it how i like) I bought a full rebuilt kit for it. including new oil pump.
When my engine gets warm, my oil pressure drops to 5 lbs. I properly installed the oil pump and primed it. I was beginning to wonder about this, and started to get pretty irritated. i installed a mechanical gauge to be certain it was true. i got p!$$ed the other day and dropped my oil pan (with intentions to put in a High Volume oil pump) and say something shiny by my cam...
This was a cam bearing. 3 of 4 cam bearings have walked out, and got chewed up by the cam. second valvetrain rebuild in less than 200 miles!! Needless to say, im pulling my engine out again.
SO... like ive read on other forums, a Jeep's low oil pressure problem could very well be your bearings. Drop the oil pan and check...
My question is... Since i cannot find a cam for a 99 WJ 4.0, are ALL 4.0L Camshafts the same? some places say yes, some places say no. Im thoroughly lost. Advance Auto Parts lists the same part number for a 99 XJ and 99 WJ for camshafts, so i would believe so...
1999 Jeep WJ
try dealer or Craigslist for a wreck.
Turbo charged G2X using tapatalk 2
id thought about that. but i put $1300 into rebuilding this engine, id hate to throw used parts in it.
2008 Commander
your likely going to need a new block... I dont know what the aftermarket has to offer but I know there is a TSB reguarding cam bearings walking out and as far as mopar options, there are none other than a motor. They walk out because there is too much clearance, and there is no fixing that without a new block.
Again, a machine shop may have a trick or some aftermaket co may have options but I have heard of no such repairs.
1999 Jeep WJ
Discussion Starter #6
Where do you find this TSB at? I checked wjjeeps.com but couldnt seem to find it. Im rather curious to read it.
The part that gets me, and leads me to believe i wont need a new block, is the fact that the factory bearings were still where they should be after 147 thousand miles. my new ones, walked out in less than 200 miles... They were also not a common name bearing (dont remember the brand) i can get Clevites from work for like $17.
1999 Jeep WJ
Discussion Starter #8
Stroker Kit!
I was considering it actually. Havent really looked into prices too much though. being as that i just rebuilt it i was just going to stick with .020 over
2008 Commander
Sorry, thinking back it was probably a starcase, which wouldnt be published to the public anywhere... ill look for it.
1999 Jeep WJ
Discussion Starter #10
If i have a sticker on the inside of my hood or core support (dont remember which) with a number hand written on it, saying "This vehicle has had modifications done... blah blah blah" and its a Chrysler sticker, is there a way i can look up that number and find what was done to it? This Jeep came from PA, I live in Ohio, and it has California Emissions. So i was curious as to what was done to it (at a dealer i assume??)
2008 Commander
that is just a pcm software update label... Your pcm has been updated in the past.
Sent from my SCH-I500 using Tapatalk 2
1999 Jeep WJ
Discussion Starter #12
oh okay. so its nothing i really need to worry about then?
1999 Jeep WJ
Discussion Starter #14
nope, not important for you.
sweet! Thank you.
Maybe one day ill learn all this stuff...
Anybody know if a 4.0 HO cam will work on my 99 WJ? probably not, because the HO was single pattern as apposed to my dual pattern. so ive read...
1 - 14 of 14 Posts
