I have a 93 grand cherokee laredo 4x4 and I have a hard shake in the front end making it undrivable I have replaced the u joints on the straight axle and it still does it ball joints are tight the faster I go it quits and when I go around corners.it.quits but.when I hit a bump it starts and I have to stop.to get.it to quit
have you looked at the front stabilizer shock? its been called the 'shimmy shock' because when it goes bad, the front end shakes.
1994 ZJ ltd.
Loose track bar is pretty common for this. Have someone work the steering wheel back and forth and look at all tie rod ends for play, or even play in the frame side track bar mount. Might want to look at the steering gear box also, as it may be loose/have broken. HTH.
Sam
