Hello! New to the forum, not to Jeep.
I recently bought a 99 WJ that has a crank no start issue. PO stated it just died driving one day.
PO told me that the PCM, Crank Sensor, Cam Sensor, and Coil Pack have been replaced.
I confirmed all of this.
Poking around I can see that the trans is a newer Jasper reman, and it looks like the engine has either been
replaced or rebuilt.
It backfired and had a weird crank sound when i cranked it.
Pulled the coil pack and it cranks normally.
I figured timing issue, so I would start by replacing the timing set. When I opened the cover up, it was fine and
correctly indexed. So I just replaced anyways as I had it open.
checked fuel pressure 50lbs, holds pressure.
I have checked the Cam Synchronizer and that is set correctly on the compression stroke.
I tested the ASD relay and that checks out.
Checked the 5v and ground to the cam and crank sensors at the sensor and at the pcm
Checked the PCM power, ground, and fuse
After getting nowhere I picked up a scope and this is what I am seeing.
Cam waveform looks fantastic, crank not so much
I have replaced the crank sensor with a mopar oem sensor.
I'm at a wall, I'm thinking flywheel? But I removed the inspection cover and don't see anything wrong.
Any help is appreciated.
