1 - 8 of 8 Posts
I have noticed ever since it has started warming up and AC was needed that sometimes when the compressor kicks on it lets out what I describe as a high pitch supercharger whine for about a second and then is fine. At times also instead of the whine it does sort of a low groan which vibrates through the pedals, steering wheel, and door panel. It seems to be only when I'm at a stoplight and its pretty intermittent. Has anyone else had anything like this?
· Premium Member
I have noticed the exact same thing and attributed it to the AC compressor because if I turn off the AC when it is happening the sound goes away.
Thats exactly what mine is doing. Took it to the dealer and of course it wouldnt do it for them so im just going to deal with it for now.
· Premium Member
SRT8
Motor Mounts and Thermal Expansion valve.
MY12 did this, Could reproduce the vibration etc but just turning the A/C on n off.
Also had a Honk goose noise vibration noise in the dash from the Thermal Expansion valve.
Maxcare took care both.
Yes, had similar. New motor mounts took care of it (Thanks MaxCare).
Glad I saw this. I just got my 11 overland 5.7 back from being repaired from an accident and I'm noticing the exact same issue. I plan on taking it back to the shop to address this because it was not happening prior to the accident.
1 - 8 of 8 Posts
