1 - 15 of 15 Posts
Grand Cherokee 4x4
So I noticed a neon green puddle in my driveway yesterday morning as I was leaving for work. I did what any guy would do.....put my finger in it and then smelled to see if I could figure out what it was. Even put a dab on the tip of my tongue and still couldn't figure it out. It wasn't coolant like I originally thought, so I figured the only other thing it might be would maybe be dye from the A/C system.
So my wife calls last night on her way home and said the A/C is acting up and making strange noises and wants me to go for a ride with her. So when she gets home, we take a cruise around the block and sure enough it's not right. Makes a gurgling sound followed by a whooshing/sucking sound about every 15 seconds. But it's still cooling. So we pull back in the drive and go inside. I promptly grab my flash light and go back outside to crawl under my WK2 to see if I can find anything.
This is what I found....
Not sure how it happened and I'm pretty certain I didn't hit anything since there's a skid plate there. Seems to be coming from somewhere higher in the engine bay and running down the length of the lines. But it's leaking pretty good and made a nice puddle in seconds in my driveway. Had I thought about it, I'd have slipped some Pig Mats under there to collect the drippings, but I didn't until this morning. Good thing I have my JK to drive, else I'd be spending the day at the dealership. As it stands, it's going first thing tomorrow morning. Will post up the outcome when it's all over.
Grand Cherokee 4x4
Discussion Starter · #2 ·
Okay, so a little update here. No call from my service advisor yesterday, even though when I dropped it off Saturday he told me he'd call by 10:00 Monday. Talked to another advisor who informed me that my advisor had the day off. Strike 1.
Got a call back form the other advisor saying they had my GC all ready to go. Said it was just a little low on Freon, so they evac'd and recharged the system and pressure tested it for leaks and it passed. So I asked the service advisor how that was possible when I physically saw with my own eyes (as did my wife, son, and of course my camera as evidenced above) and he said the tech didn't find anything. I told him I showed my advisor pictures of what was going on and of course that information never made it back to the shop, even though there was a tech looking at it on the service drive Saturday as I was leaving. Strike 2.
So he puts me in touch with the dispatcher and I explain all of what's going on. And being a former service advisor for 8 years myself, I ask the dispatcher what the advisor had written in the description for what I said was wrong. The description read "Not cooling. Has leak." In the immortal words of Arlee Arnee in Full Metal Jacket...No Shit! So I explain the entire story to him and tell him I'll email him pictures to show what I found. And I share the entire story again in an email just so there's written proof.
I finally hear from my advisor this evening about 6:00 pm CST saying they have it figured out and it should be done tomorrow, but it's currently got the dash removed. Says he'll send me pictures.
This is the current status of my 2014 Grand Cherokee Limited 4x4 as it sits at this moment at the dealership.....
The only two words out of my mouth when I got the picture were probably the same one's you're all thinking....
Holy Shit!
More updates when I get them....
Good luck. Those pics are scary. I would be nervous about them putting it back together correctly.
I had a new VW GTI that was 3 months old in the shop for 40 days. That is not a typo. I showed up once a week and my car was literally in pieces, engine taken apart and they still couldn't find the issue. Finally, they replaced some internal part that had broken (a tooth from a part had broke off). Needless to say, I fought VW and told them I wasn't taking the car back. After a month or so, they gave me a brand new one. That was 10 years ago and it is still running strong.
What gets me the most, how can they say it passed a pressure test? There is no way they pressure tested that system, the just filled it and out the door.
After looking at that picture of your stripped interior, I'd feel totally violated if that were my vehicle! :eek:
Grand Cherokee 4x4
Yeah......I'm less than pleased about the whole ordeal. I'm fairly certain it'll never be the same again and I'll never be rid of squeaks and rattles. And being only 4 months old I can promise I won't stand for that long. I have a feeling it's all headed downhill from here....
How did it turn out? I have a 2011 JGC and similar problem. A/C cools for a week or two then nutn. Good air flow coming out just not cold. We've taken it in 3 times already and they say its fine we tested it no leak yada yada yada. They refill it and out the door. I can bet anything we'll be back in a month or so.
Banned
being a former service adviser im sure you are aware that fluid you see has nothing to do with the internal operation of the a/c, as refrigerant boils off at atmospheric pressure.
id be more inclined to think it were coolant but arent you guys running the pink stuff? could be dye but that usually isnt introduced into the system until there is a suspected leak. where does the condensate drip out at? anywhere near the wet places in youre pic?
Grand Cherokee 4x4
Discussion Starter · #10 ·
Unless there is a leak somewhere in the system, the A/C will not lose refrigerant, at least not that much that fast. The picture that shows the puddle under the vehicle....that puddle formed in seconds...long enough for me to walk in my house grab a flash light, and go right back out.
And I knew it wasn't coolant because I smelled and tasted it earlier in the day. And the color was a bit lighter than the green coolant, too. And I believe we do indeed use pink/orange coolant. As far as where it was leaking from, though...couldn't tell you. My service advisor couldn't even tell me what parts they were replacing. And I called Friday to check status and he said it was put back together, but it was throwing codes. So I promptly asked what it was throwing codes for....and he didn't know. Said it would be done Saturday.
Got a call Saturday saying it was throwing codes for a clock spring and they didn't have the part, but they were having it sent overnight and would have it in and everything done by this evening.
Obviously with the way things have gone to this point...I doubt it.
What a friggin' nightmare! :eek: Geez! I hope they can somehow get your Jeep back together correctly and working properly again. Don't think I'd ever go back to a service manager who says "I don't know" so much. Totally unacceptable. :slapfight:
Banned
jeez gives me visions of them using youre jeep as a learner vehicle, i can invision them having all the techs sitting there watching the head tech rip youre dash out, all the while giving pointers and dos and donts, while the younger techs eat doughnuts and tweet the whole time. well lets hope not. good luck
Grand Cherokee 4x4
Discussion Starter · #13 ·
Currently sitting at the dealer waiting for them to put gas in it......30 minutes and counting. Turned out to be a bad evaporator core, which would explain them pulling the dash out. I'll report later on whether or not there are rattles or other noises that will make me bring it back.
Have I said how much I hate dealerships......
Grand Cherokee 4x4
Discussion Starter · #14 ·
So a little update here. After waiting for 45 minutes for the service advisor to put gas in my GC, he brought it up so I could leave. I opened the door and there were grease marks all over my interior.....my light beige interior. It literally looked like the tech rolled around in grease and then decided to drive my vehicle, touching anything and everything he could get his filthy hands on. And the exterior wasn’t much better. I had it detailed a few days before taking it to the dealer and now it had greasy hand prints, etc. all over the interior and some on the exterior, too. Needless to say I was pretty agitated at this point. I pointed it out to the service advisor, who then explained that he could take it back to the details shop if I had a few minutes to get it taken care of. I was already almost an hour late to work at that point, so I told him I’d just bring it back. Threw my shit in the passenger front seat, got in, and attempted to drive away. I turned out of the parking lot onto the service road and my traction light came on immediately. I kept driving trying to see if it would go off, trying to figure out what it could be. Got just past the stop light when I realized my steering wheel was off center. We’re not talking off center just a little….we’re talking off center between 2:00 & 3:00! WTF!!! At that point, I ****ing lost it! I was so pissed off I put the pedal to the floor and hauled ass back to the dealer. I called my wife on the way to let her know what was going on and threw f-bombs out left and right which probably didn’t make her too happy.
So I get back to the dealership and my advisor comes over to see what’s going on. I explain about the traction light and the steering wheel and tell him straight up that I’m pissed and want to talk to the service manager. So the service manager comes over and I explain the situation and they agree to put me in a loaner vehicle since I’m now without transportation for the day. I then ask to speak to him in his office. So we go to his office and I put everything on the table at that point. I explain about the horrible customer service I got from my advisor, I explain how pissed off I am about the condition of my vehicle when I pick it up and that they should have much better quality control measures in place. I explain about the 45 minute wait to get fuel in my GC, to which he says he was hesitant to let the advisor put fuel in it because they don’t provide for loaner vehicles. I told him I thought they provided them if the vehicle had to be there more than 24 hours and he said Chrysler doesn’t operate that way (disappointing). He did say, though, that he felt better about putting gas in mine for me after hearing the situation went the way it did. He also said he’d take care of the communication problem and that they’d make my GC right again. I told him it better look brand new when I pick it up, so we’ll see how it goes. At that point, Enterprise was there to pick me up. Then it took me another 45 minutes or so to get a car. Come to find out, though, those guys don’t like my advisor, or the dealership, either. GO figure.
Got a call late yesterday evening (5:45-6:00) from the advisor saying that they had to order a clock spring and it would be there this morning. They were supposed to have done that Saturday when he called, but instead, they just tightened the connector that supposedly wasn’t connected completely. So after all that, I’m still without my GC and currently driving a crappy Dodge Avenger, although I could’ve had a Challenger if not for my kid’s big ass Recaro car seat.
Guess I’ll update again when I pick it up…..or at least attempt to….
Grand Cherokee 4x4
Discussion Starter · #15 ·
Okay, so sorry for the novel I posted last. Just had a bad experience with the dealership and couldn't really shorten it up much without leaving out details.
So I picked it up Friday and it's fixed, with no rattles or other annoying noises even. But they did miss a couple spots that still have grease marks, so I need to have them take care of that. Not that I can't do it myself, but I'm dropping it off again tomorrow night to have a scratch on the rear seat leather repaired, so they may as well clean the spots, too.
But the A/C blows cold and works as it should and so far I don't see/hear/feel anything out of the ordinary. I do need to have the tires balanced, though, which I already knew, and apparently it needs an alignment, too, but I can handle that. I had a feeling it would anyway. At least the steering wheel is within a couple degrees of center at this point. I will say that I'm definitely happy to have it back, though. As much as I love my Wrangler, it's no daily driver, and certainly doesn't offer the same driving experience my GC does. But it sure was fun wheelin' it Saturday! Hope to have that video up later in the week.
But for now....this issue is a done deal.
1 - 15 of 15 Posts
