Just purchased a used 2006 Jeep Grand Cherokee Laredo. Couple of times now I will be taking off and all of a sudden it feels like I am dragging something. Barley moves and abs/ traction light comes on. Vehicle will work normal and lights go off little later.
Any clues?
High altitude
if your able to get some codes it would be easier to try and diagnose. could be a wheel bearing, wheel speed sensor, wiring, abs module ect. a code will help narrow it down.
High altitude
The light comes and goes. To get codes they need to be on correct. Thanks
The codes should be stored in each of the modules. Even if the lights are off the codes will be stored in the system. If the lights are on the code is active which means the problem is happening at that time(also the best time to diagnose). Even though they are stored it will give you a path to go down. Circuits to visually check for any nicks or signs of corrosion. Connectors to inspect. Powers and ground to check as well. Intermittent problems are difficult to diagnose but sometimes you get lucky and find something while your inspecting the circuits.
