Hi. I read your post and the replies with interest as I would like to upgrade my front and rear speakers and sub in my 2012 JGC Limited. Can you provide some advice and input? My broad question is, how did you handle the factory amp, center speaker and rear pillar speakers? The shop and an AudioControl rep recommended using a lc7i and EQS equalizer (I'm on board with the eq) . But some of this depends on what comes out of the factory amp.
If the rear door woofers and back pillar speakers/tweets run on one input, I may just replace the door speakers with two way coaxial speakers and disconnect the pillar speakers. If they are separate leads from the amp, can the wires be combined so I can get full range in back doors instead of just low frequency? Having coax in rear doors doors will enable me to benefit from new amp and equalizer. I assume the front door speakers are component. I plan to replace with a 6.5" component or 6.5" focal component. The equalizer will enable me to tweak the sound for better balance of mids and lows in front. (Factory set up doesn't do it for me)
Also, did you run your new Is your take more fun than ours after the factory amp or run the speakers directly to the new equipment? If the latter, duff you lose any functionality from the Uconnect system (e.g., navigation voice, etc?) Or dues that run completely out of the head unit?
So confused! Any advice and info is greatly appreciated. Pardon any typos...I'm using a phone.
