1 - 20 of 24 Posts
Boosted Turd
2010 JGC SRT8
As stated above, my airbag light keeps turning on then off randomly. It seems to only do it when it's warmer outside. Has anyone else had this problem and might have an idea what the issue is?
The beast from Brazil
The airbag control module (ACM) is continuously monitoring the supplemental restraint system components. If it sees a fault, it will switch on the airbag indicator light and store a DTC in its internal memory. You will need a DRBIII scanner or alike to interrogate the ACM and find which component is causing the light to come on.
Air bag recall? Isn't it in 10 years if service from date of manufacturing it is to get looked over by dealer?
Sent from my LG-P999 using Tapatalk 2
Boosted Turd
2010 JGC SRT8
I pull no codes on my scanner. And it's just weird how it just started doing it one day. And only when it's warm out....
Do you have the right scanner to scan the ACM? The normal scanners only interrogate the PCM.
Boosted Turd
2010 JGC SRT8
Maybe that's why. My scanner only scans the PCM.
A local garage overhere is using some kind of chinees scanner, and it can access all the different computers and run tests on them. It only couldn´t do the transmission control module Quick learn procedure for me which was necessary after the tranny rebuild. I found a tranny shop nearby which has the original Chrylser DRBIII scanner and with that one you can do all kind of things.
Boosted Turd
2010 JGC SRT8
Quick question, i did some research and people are saying its the ACM thats bad so ill give it a try replacing it. But the question is, do you have to match the ACM with the airbag or can i just leave my airbags and just replace the ACM? Thanks guys.
You could.just change the ACM and leave the airbag, but there are more components in the system then these two. There are also belt tensioners. A bad squib in either one of these components or a wire.problem.could already give you the light. Dont know the price of the ACM, but could you.not better scan.it somewhere then just throwing money to it without knowing the real problem? If you want to change it, it sits just behind the gear lever assy.
Boosted Turd
2010 JGC SRT8
Discussion Starter · #10 ·
I bought a used one for $30 so I'm not to worried about wasting the money plus I'm having a problem finding a place to do the scan since I don't want to go to the stealership! Lol
Take care that there are two types of ACM, with or without side curtain airbags. Also the ACM has an accelerator sensor build in, so dont drop it or handle it roughly. It could cause accidently deploying of the airbags or no deploying when needed. Disconnect the battery and wait half an hour before attempting any maintenance on the airbag system. Seems that there is a capacitor inside the ACM which still can/ will deploy the airbags with the battery disconnected after some time.
Boosted Turd
2010 JGC SRT8
Discussion Starter · #13 ·
That was my next guess is the clockspring but i read on another forum that many people replaced the clockspring first to no avail.
You could spend a lot of money changing out all kind of components without knowing the real reason. Its just shooting in the dark.
There are no larger carpart shops in your nabourhood where they can do the scan for you?
Boosted Turd
2010 JGC SRT8
Discussion Starter · #15 ·
None of the places i called could scan it or even recommend me to a place. Yeah i know its a shot in the dark so i guess we will find out when i swap them out lol
But did you get the right ACM for your jeep?
Boosted Turd
2010 JGC SRT8
Discussion Starter · #17 ·
Yes i contacted them and made sure it was from a 99 jeep like mine since side airbags weren't available until i believe 2002?
2003 Grand Cherokee
Let us know whatever you find out. Mine's been doing the same thing, but I haven't had time to take it to the dealership to pull the code.
I've also heard clock spring, but I'm hesitant to spend $100 on a part w/out having the code pulled.
1 - 20 of 24 Posts
