1 - 10 of 10 Posts
Hi there... wondering if anyone has any advice or opinions on my A/C problem as described below. Thanks in advance for your feedback.
Vehicle = 2012 V6
Repeatable issue during highway / freeway driving at outside temperatures above 100 deg:
  • air initially cools down to near 40F for some time
  • cold air flow begins to noticeably decrease
  • cold air temp starts increasing to greater than 80F (at which point its getting too hot in the cabin)
This was during a recent family trip from AZ to CA naturally, and I started freaking out. I decided to cycle the A/C OFF for about a minute or two while letting it blow "ambient" temp... the flow increases back to "normal" and warms up... I then turn A/C back on... it goes right back to blowing cold. This "cycle" repeats regularly during highway driving (over 65 MPH).
I figure its freezing up for some reason, but it also seems somewhat dependent on engine load/demand.
80K miles, never had an A/C service.
Thoughts?
Vehicle = 2012 V6
Thoughts?
Get the pressure checked. It could be low on freon, or a leak. Check cabin air filter too. Also listen outside of the cabin for a somewhat high-pitched whining or squeaking noise while idling,
Vehicle = 2012 V6
Thoughts?
Those are all the classic symptoms of a low refrigerant charge. At 9 years of age loss of enough refrigerant to be "low" is within design parameters, at the high end but still within "normal" loss. Any shop should be able to assess and recharge. If they tell you you need more than a recharge be suspicious and take it elsewhere for a second opinion.
Agreed.
Although still listen for that sound I mentioned. If you hear it..it could be a bad pulley on the AC compressor unit.
Thanks guys... definitely no strange noises going on. I'll move on to getting the system checked for charge/leaks.
Reactions: PowerJRod
Well to close the loop on this one -- Sun Devil Auto recharged it and replaced the test port valves/plugs, no leaks detected at the time. System runs great so far!
As a side note -- it cost me $190 to get this done. Manager there says "newer" systems (the fancy environmentally friendly stuff) can cost at least $550 and some places charge up to $1K for it. Yikes!
High altitude
Hopefully they added dye to the system so when the charge gets low again they can use a UV light to find the leak.
2019 Grand Cherokee Trailhawk
Thanks for coming back and posting the resolution of your problem. Nice when members do that, particularly newer members. That's what keeps these forums going. And, glad you got your problem figured out, and at such a reasonable price.
Keith
Discussion Starter · #10 ·
yes there is dye in the system, i'll take a look myself after a few days of use.
Reactions: Meanmrmustard
1 - 10 of 10 Posts
